convection oven
Submitted: Thursday, Jun 02, 2011 at 19:35
choc
Has anybody got the brand of a small convection/micro wave oven that will fit van .Max size 495 wide x 375 high
Reply By: Holiday Maker - Thursday, Jun 02, 2011 at 19:38
We just removed the microwave from our caravan and installed a Breville Pronto convection oven.
There are a number of brands around.
I just went into a couple of stores with a tape measure, the big difference is in the quality.
The only compalint I have is that the door need some form of outside assistance to stay closed in the caravan enviroment.
Dusty
456175
Follow Up By: choc - Thursday, Jun 02, 2011 at 19:56
i would prefer a combined micro/convection oven.
Has to fit in existing space.
729181
Follow Up By: Puma1 - Thursday, Jun 02, 2011 at 22:42
Here you go
Specs:
Model Number: KGNMWC25VAA
Rated Voltage: 230-240V 50Hz
Input Power (Microwave): 1400-1500W
Output Power (Microwave):
900W
Output Power (Grill): 1100W
Output Power (Convection): 2250-2400W
Oven Capacity:
25L
Turntable Diameter:
315mm
External Dimensions: W:51.3cm x D:46.6cm x H:30.5cm
Internal Dimensions: W:33cm x D:33cm x H:20.5cm
Net Weight:
Approx. 17.7kg
http://www.kogan.com.au/shop/25l-convection-microwave-oven/
I bought one it's really quite good. At this price you just can't go wrong!
Cheers Nigel
729213
Follow Up By: choc - Friday, Jun 03, 2011 at 07:55
SPACE AVAILABLE IS 495 X 375.
OVEN TOO BIG WITH OUT CUTTING TO CUPPBOARD AREA
729232
Follow Up By: den57 - Friday, Jun 03, 2011 at 18:49
We looked at a Panasonic convection /microwave oven as they don't have a
turntable which means you can put a rectangular dish in the oven that takes up the full oven. This particular model has the beam for the microwave in the top of it and the beam is made to rotate. Sounds great but when you read the fine print it requires 10 cm clearence on each side and i think it was 20 cm clearence at the top. Couldn't afford to waste that much space, and therefore more suited to sit on a bench , but, bench space is too critical as
well. Had to give it a miss.
Would be careful about replacing a microwave with a convection oven as i would assume they all need a certain amount of space due to the heat in the cooking process. Not worth risking the van for it.
Den n Col
729313
