Nitmiluk National Park
Submitted: Tuesday, Jun 07, 2011 at 19:42
ThreadID: 86823 Views:3686 Replies:7 FollowUps:12
Hi guys,
Basically is it worth it?
I understand most people are going to say yes. Which is fair enough. It does look very impressive!!
We leaving Darwin shortly to head to WA.
We are considering ducking down to Katherine over the long weekend to do the Katherine Gorge tours.
We have done Carnarvon Gorge in Qld, Kings Canyon and Ayers Rock, and Kakadu and Litchfield.
How does Katherine Gorge compare?
Is it worth the $$$ and a special trip down there?
We are trying not to do it on the way out of Darwin as we are on a bit of a time frame to get to Perth.
Clint
Reply By: Member - Kevin S (QLD) - Tuesday, Jun 07, 2011 at 19:59
Hi Clint. Katherine Gorge is quite different to the other places that you listed and you see this one by boat. Take the lunch cruise. It really adds to the experience and they served a good meal when we were there last year.
Kevin
Kevin
2019 Mitsubishi Cross
AnswerID: 456724
Follow Up By: Clint & Chell - Tuesday, Jun 07, 2011 at 20:02
Cheers.
Thanks Kevin.
Should probably mention we'll have an 8yo & 5yo in tow.
Not sure if that'll make any difference.
FollowupID: 729824
Follow Up By: Member - Kevin S (QLD) - Tuesday, Jun 07, 2011 at 21:43
The lunch cruise did two gorges. Main course on the outward journey and dessert on the return. You get a walk to and cruise on the second gorge between courses. I don't remember exactly but I think there were children on board. The walk between the two gorges is well paved and safe to walk on. They get a lot of elderly people taking the cruises and have put a great deal of effort an making it safe.
Kevin
Kevin
FollowupID: 729845
Reply By: Motherhen - Tuesday, Jun 07, 2011 at 22:26
Hi Clint - you need to see it by boat as the walks are long and away from the gorge with side spurs too it. Should be fine with children. It was a gorge we enjoyed and one on my list of must sees along the way. We also went to Edith Gorge - quite a long walk up to the falls and back. We stayed on site at both places. All you have mentioned are very different to Katherine Gorge as they are to each other - can;t compare. They are all special places that i would put high on my list of must sees.
AnswerID: 456745
Reply By: Member Al (Sunshine Coast) - Wednesday, Jun 08, 2011 at 08:24
Hi Clint.
Katherine Gorge is the Katherine River and to traverse within the gorge itself means going by boat. The river comprises a string of waterholes (19 I think) with the rocky stream connecting them. There is a boat on each of the first 7 waterholes and you have to walk the easy and short distance between each. It is quite different from most gorges and well worth seeing. The kids should handle it OK. Overview websites are here and also here. Google "Katherine Gorge" for more info.
It would probably pay to pre-book the boat tour. We did the full-day 7-gorge tour which included a barbecue lunch. The boats are the usual covered tourist boats and quite safe for children.
An interesting aspect is that an absolute torrent of water rushes down the gorge during The Wet and the boats must be removed. They wait until the water rises above the interconnecting rocky sections then drive them out like surf-boats! Similarly they have to take them back in before the water falls too low at the end of The Wet. No easy task.
AnswerID: 456752
Follow Up By: jothefw - Wednesday, Jun 08, 2011 at 09:45
I concurr with most said although when we did last year (mid July) we did 4 gorges - so whether the number depends on how high the water levels are? We did the complete day.
With a 7 yo and 9 yo at the time. They loved it. Loved the last bit where we could swim.
Well worth it.
Did Edith too and loved that too - but the boat experience of Katherine was extra special. We just loved Katherine as a whole though - much drier heat which suited us South Australians!
FollowupID: 729874
Reply By: get outmore - Wednesday, Jun 08, 2011 at 12:17
that place was both a highlight and low light
kyacing 4 gorges was simply breathtaking especially the turtles coming over to check me out as i rested under a big overhanging cave
lowlight was I had to pay to take MY kyac down there to discoarge BYO and protect the kyac hire operater there
AnswerID: 456771
Follow Up By: jomahk - Wednesday, Jun 08, 2011 at 15:56
If you own a kayak; you should know how to spell it as well as paddle it -kayak. And so ends my spelling lesson for the day. Keep smiling & the world will smile with you.
FollowupID: 729909
Follow Up By: get outmore - Wednesday, Jun 08, 2011 at 20:24
its my kyac and so ill call it what i want :-)
FollowupID: 729943
Follow Up By: Member - Royce- Thursday, Jun 09, 2011 at 14:01
We kayaked it too..... nicest way to see IMOH
jomahk...take it easy. I'm a teacher and certainly shuddered at the spelling, but my guess it that this is a case of someone enthusiastically answering, but with limited skills. Good on you get out....
FollowupID: 729993
Follow Up By: Member Al (Sunshine Coast) - Thursday, Jun 09, 2011 at 17:55
Royce, jomahk, "get outmore' and others,
It's interesting that if you suggest a particular type or brand of battery is the 'right' one, or maybe that its useless to add 2-stroke oil to diesel, or even that Hiclones are the best thing you can put on your engine, then people believe its OK to jump all over you with disdain. However should you dare to point out that someone cannot spell 'their' or uses 'loose' instead of 'lose' or even 'kyac', or any other stupid basic spelling or grammar error then you are denounced, vilified and condemned as a Spelling Nazi. Correct any technical point, correct the precise location of a geographical feature but do not dare to suggest that someone is in error with spelling even the most basic words!
If the errors go without correction, will the transgressor ever learn?
I take my hat off to jomahk for his courage.
However, I must say that I was impressed with Get Outmore's response....."its my kyac and so ill call it what i want :-)" Gold!
FollowupID: 730023
Follow Up By: Member - Royce- Thursday, Jun 09, 2011 at 18:11
Al... you didn't understand my post. I detest slack spelling.
Sometimes though people have a severe problem.... dyslexia. You can usually pick them as a teacher. [I may be wrong]
If they spellcheck.... they can't work out even from that, the correct spelling.
My point was that you have to be careful. It's like yelling at a deaf person to listen more carefully, or a blind person 'are you blind... watch out!"
A bit of tact doesn't hurt.
My pet hate is ect. !!!
FollowupID: 730025
Follow Up By: Member Al (Sunshine Coast) - Thursday, Jun 09, 2011 at 21:10
No, no, no Royce, I really did understand your post and where you are coming from. I saw your shudder. My post and comments were not directed at you or what you had said. I included your name in my address because you and the others were part of the sub conversation. And I agree absolutely with your sentiments.
It was just that I have so often winced at the indifferent spelling appearing in our society and reflected on the reaction to criticism. Jomahk's and your expressions provided me with opportunity to comment on that.
I appreciate that dyslexia etc can be a problem but my observations are that so much of poor spelling is because persons have learned phonetically. The thing that really gets me though is that even when confronted with the correct spelling, 'their' for example they do not seem to say to themselves "hullo, what is that word?" and learn. Even worse is the deliberate debasement such as using '2' instead of 'to'. As I read and encounter '2', as a technical person I see a numerical quantity and it throws me off the subject with irritation.
Why then is tact appropriate here when it is not called for when a person makes what may be considered an 'error' in expression or opinion? There seems no hesitation in voiced correction then.
And what may I ask is wrong with using ect or "electroconvulsive therapy"?
But enough, I may be hijacking the thread. Although to start a fresh one may be moderated as being Off Topic.
FollowupID: 730044
Follow Up By: get outmore - Friday, Jun 10, 2011 at 09:24
I must admit with the internet and computers my spelling has got slack to the point I write a word - can see its not right and go ' oh well theyll know what i mean"
and as for grammer............
FollowupID: 730069
Reply By: Dawg13 - Wednesday, Jun 08, 2011 at 16:24
Hi there Clint,
i guess i am lucky (or unlucky depending on how you look at it) to be living 15kms from Katherine. basically Katherine gorge is a nice place to visit though it is rather limited in where you can go. like most people have mentioned the boat tour is your best bet and i actually did the boat tour about 4 weeks ago and can post that the water was still quite high and the gorge was looking great. Edith falls is also part of the Nitmiluk nat park and if not done yet also a great place to visit. the walk up to the top pools (approx 2km round trip) is worth it and allows for a nice cool off up in the falls.
if you do decide to visit the gorge you only need a couple of hours and i would advise to stay away from camping there as the bats are annoying in the camp ground...when i stayed a few weeks ago they kept everyone up all night and covered our vehicles with bat poo...
hope this helps with your decision.
Dawg 13
AnswerID: 456787
Follow Up By: Clint & Chell - Wednesday, Jun 08, 2011 at 18:36
thx everyone.
that helps a lot.
happy travels. :)
FollowupID: 729922
Reply By: Member - Jo Q (NSW) - Thursday, Jun 09, 2011 at 13:01
Hi Clint & Chell,
I did the lunch gorge cruise as well with me daughter who was 7 at the time - well worth it & she thoroughly enjoyed.
Not cheap - but what I would highly recommend is a helicopter flight. We did the one that landed on top of the gorge & we got out to look at the fabulous views - a great experience for both myself & my daughter.
Enjoy,
AnswerID: 456871
Follow Up By: deserter - Thursday, Jun 09, 2011 at 17:20
I've done the boat thing twice - but the helicopter is fabulous. Touch pricey with kids though.
FollowupID: 730017
Reply By: Member - Royce- Thursday, Jun 09, 2011 at 14:02
A magnificent part of Oz... sadly now a 'resort' and very touristy.... if you can get away from the crowd and imagine that you are the only people there.... lovely.. Kayaking does it nicely.
AnswerID: 456877
