Thursday, Jun 09, 2011 at 15:39
In the early 60's, the old man had an English Field Marshall, 6-litre, single cyl tractor for pumping on the farm (also
Donnybrook) - like above, he mounted a 4" pump on the front of the tractor and ran belts off the flywheel. Whereas the Lanz used a blowtorch to heat the pre-ignition chamber, the Field Marshall used ignited paper treated with salt petre. The paper was rolled up, ingited and inserted into the cylinder head on a long shaft and tightened down. The engine could then be started from cold, the burning paper lasting long enough to allow the
fuel to burn from cold. For really cold starts, the engine also had a shotgun cartridge, specially made for this tractor. Basically a normal cartridge without the lead shot. This was mounted in a breech, and fired. The charge went through a pipe into the cylinder via the decompression valve. Worked every time, but it was an expensive way of starting the tractor, so it was only used for really cold starts. But it took some practice to get it started with the crank. One had only 4 turns of the crank before the decompression valve shut. As a skinny 17yo, it took quite a technique to master getting a 6L engine with large flywheels up to speed in 4 turns!
Many farmers bought up these old single cylinder tractors quite cheaply for irrigating, as they had limited use as a proper tractor, but were wonderfully reliable and economical as a pump engine.
Gerry
730001
