Patrol Stereo Antenna Adapter
Submitted: Sunday, Jun 12, 2011 at 20:20
Patrol GU VI
I have an after market Pioneer stereo system in my 08 Patrol. For the Aerial connection, it requires an adapter from the OEM 2 pin antenna plug (1 pin for the body mounted antenna, and the 2nd pin for the rear window antenna I believe) to a single antenna plug in the radio. Picture of the adapter is here.
Antenna Adapter.
I think that there may be a problem with the adapter and was wondering how to check it. I have run a voltmeter over the adapter and through the outer edge of the plug and it seems to have a good connection, but if I test where the pin OEM pins go in to the large PIN on the single plug end, there seems to be no reading.
Am I testing this right, and if not, how do I test it??
Many thanks in advance for your replys
