fuel calculator
Submitted: Thursday, Jun 16, 2011 at 07:43
ThreadID: 87024 Views:3880 Replies:6 FollowUps:13
Can anyone give me a tip on a fuel calculator ,work out fuel usage on trip .
regards nick
Reply By: Kev - Member - Wynnum - Thursday, Jun 16, 2011 at 08:04
Hi Nick,
I have an Excel sheet that calculates fuel usage, power usage and a couple of other spread sheets.
I could E mail it to you if you wish.
AnswerID: 457584
Reply By: Sir Kev & Darkie - Thursday, Jun 16, 2011 at 08:09
Nick,
There is one in the Members fileswap ;)
Cheers Kev
Russell Coight:
AnswerID: 457585
Follow Up By: Member - barry F (NSW) - Thursday, Jun 16, 2011 at 09:16
Handy info there Kev, Big Mal should have a look at so his boys are better equipped with the appropriate amount of fuel whilst on a trip. Thanks & cheers
FollowupID: 730757
Reply By: Member - Bruce C (NSW) - Thursday, Jun 16, 2011 at 10:23
Hi Nick,
I have one of those slide type cardboard calculators which I can email you if you like.
Just print it out on a manila folder cut to A 4
Cut on the dotted lines and fold up and there you have it.
If you would like a copy of the calculator email me
alanvale at midcoast dot com dot au.
AnswerID: 457597
Follow Up By: new boy - Thursday, Jun 16, 2011 at 11:16
Is this the Castrol one?? thier,s is a very good one Ks per litre, miles per gallon k,s per 100ltrs along with other conversion Ks to Miles Feet to Mtrs ect. I got mine from a Castrol agent few year ago don,t know if they still supply them.
FollowupID: 730771
Follow Up By: Member - Bruce C (NSW) - Thursday, Jun 16, 2011 at 11:37
New boy, I would not have a clue. It was given to me as an image file so I cannot see anything on it that says where it came from or any advertising of any sort.
It does have most of the the things you say but is only a fuel calculator, no feet to metres though.
Bruce.
FollowupID: 730775
Follow Up By: Member - Bruce C (NSW) - Thursday, Jun 16, 2011 at 15:02
Nick, in case you were wanting a method to calculate it yourself I will include a
simple method for that.
Take the kilometers travelled and divide by the litres used
This will give the kilometers per litre.
Divide cost of a litre by the kilometers per litre.
This will give you an average cents per kilometer.
Divide this figure (kilometers per litre) into 100
This will give litres per 100 kilometres
Example
Lets say we traveled 350 kilometres and used 50 litres of fuel
350 Km divided by 50ltr = 7 kilometres per litre
Assume average litre of fuel cost $1.45
$1.45 / 7 = .207 this is 20.7 cents per kilometer
or if you like –
reduce the cost to cents per litre
145 cents per litre divided by 7 Km per litre = 20.7 cents per Km
To calculate the litres per hundred kilometers
Take the kilometers per litre (in the example = 7)
Divide that into 100 (100 / 7 = 14.28)
This gives the litres per hundred Km = 14.28
Cheers, Bruce.
FollowupID: 730791
Follow Up By: Isuzumu - Thursday, Jun 16, 2011 at 18:36
Good one Bruce, that's what I do to. Another good idea is to buy a Outback Trip Log from EO and keep all your records of fuel use there.
FollowupID: 730812
Follow Up By: Member - Rod N (QLD) - Thursday, Jun 16, 2011 at 19:02
I made my own Excel spreadsheet that uses those formulas. I keep a record of all my trips that way. I'm sure that any of the ones in the file swap page do the same.
FollowupID: 730815
Follow Up By: Member - Bruce C (NSW) - Thursday, Jun 16, 2011 at 19:27
Rod,
I use a spreadsheet to but but not everybody is conversant with spreadsheets and many of us do not like to admit we do not comprehend computers all that well.
I run the spreadsheet for all costs on the road. Probably wasting my time but it helps plan the next trip provided I factor in price rises.
For quick calculations I use the card board slide calculator which is kept in the map pocket on the door. It's just more convenient when in a hurry.
Cheers, Bruce.
FollowupID: 730820
Follow Up By: Trev6 - Thursday, Jun 16, 2011 at 21:02
If you only need fuel usage and not so much the cost you can do it by converting your Km,s to a decimal
eg: (Taken from Bruce's example) 50L fuel and 350km .... 50 / 3.5 = 14.28 L/100 Km or
785 km and 90L..... 90 / 7.85 = 11.46
this is an easy way of monitoring it while driving when you have used say a quater or half tank of fuel, other than that all you need is a calculator or a good mathamatic mind
hope this helps
Trev6
FollowupID: 730829
Follow Up By: Member - Terry (SA) - Thursday, Jun 16, 2011 at 21:23
Further to Bruce C and Trev6 example you can take the equation one further step and convert back to the old MPG, using a factor of 282.48.
Divide 282.48 by the L/100Km to get MPG
eg: 50L fuel and 350km .... 50 / 3.5 = 14.28 L/100 Km.
282.48 divide by 14.28 = 19.78MPG
Terry
FollowupID: 730833
Follow Up By: Trev6 - Thursday, Jun 16, 2011 at 22:18
Thanks for the extra tip Terry, I would definitly need a calculator for that one as the brain power won't stretch that far.
Trev6
FollowupID: 730840
Follow Up By: Member - Rob Mac (QLD) - Thursday, Jun 16, 2011 at 22:37
Hi Terry, I always convert my usage back to MPG (beacuse I can "picture" it better in my mind) the method I have used for years is as follows this is my rear tank I filled tonight; 700km divided by 71.91lts =9.734 (klm/lt) multiply by 4.54609 divided by 1.61 = 27.51mpg. Thats running empty to and from work on Ipswich m/way each day , anything over 25mpg I reckon is good for a large vehicle.
Rob Mac
FollowupID: 730845
Reply By: Patrol22 - Thursday, Jun 16, 2011 at 17:54
There is a hand website that allows you to store the info and also post it to you forum signature on most forums. See HERE!!
AnswerID: 457629
Follow Up By: 944runner - Thursday, Jun 16, 2011 at 21:52
thats the one I use as well, handy little free website.
FollowupID: 730834
Reply By: Member - nick b - Thursday, Jun 16, 2011 at 19:22
Thanks Bruce C and all that replyed that was great thanks .
cheers nick
AnswerID: 457637
Follow Up By: Member - Bruce C (NSW) - Thursday, Jun 16, 2011 at 19:32
Allways happy to help Nick.
Cheers and happy travells, Bruce.
FollowupID: 730821
Reply By: Member - Rod N (QLD) - Friday, Jun 17, 2011 at 06:36
For those with the so called 'smart phones' there are apps to do the work for you, There are a heap of android ones but I haven't tried one yet.
AnswerID: 457671
