1990 nissan terano r3m 2.7 td
Submitted: Friday, Jun 24, 2011 at 08:51
steven c1
just a few inquiries about my newly purchased terrano, firstly where can i find a translation for the fuse box as its all in Japanese? next question does anyone know what the hold/AT/power switch does? ive tried using it but it doesn't seem to make any difference. and lastly how does the touring/sports
suspension switch work? ive also tried it but it doesn't seem to make any difference. any help would be greatly appreciated.
Reply By: Robin Miller - Friday, Jun 24, 2011 at 09:26
I don't know Steve - but you could try Nissan help line on 1800 035 035
458314
Follow Up By: Shaker - Friday, Jun 24, 2011 at 09:42
I think you will find that Nissan have no interest in "
grey imports".
731775
Follow Up By: Robin Miller - Friday, Jun 24, 2011 at 09:50
Hi Shaker
I have a vague memory of it being road tested once by RACV , they considered it an under rated car , so I thought they may have once been sold here , maybe someone can confirm.
Bit of advice in thread 41244 also.
731776
Follow Up By: Shaker - Friday, Jun 24, 2011 at 10:03
The only Terrano sold new in Australia was the Terrano II, in both diesel & petrol. It was sold here with Pathfinder badging in almost poverty pack form.
The 2.7 TDI diesel version would have to be one of the most under-rated vehicles in Australia.
731777
Reply By: Rob! - Friday, Jun 24, 2011 at 10:36
Steven,
I've got the translation at home, so I can email to you but not until after the weekend. What's your email?
AT switch
"AT" = Standard;
"power" = as with most cars' power switches, it provides a little more power, probably by staying in gear longer and perhaps letting the transmission slip a little.
"hold" - reduces power by switching up a gear earlier and limiting slip in the transmission. For use on slipery surfaces like snow and maybe sand. Most new european and japanese cars have this switch indicated with a snowflake.
Suspension
Touring/sports
suspension switch will only work if you have the original shock absorbers on the car. If you look at them there is a wire that is connected to them at the top. From memory "touring" gives soft
suspension and "sports" gives hard
suspension. To check if it works, set it to touring, get a friend to rock the car. While they're rocking it, switch to "sports." There is a very noticable difference between the two.
R.
458324
Follow Up By: Shaker - Friday, Jun 24, 2011 at 10:41
I would have thought 'HOLD' would have meant that it would hold in the selected gear for steep descents.
731785
Follow Up By: Rob! - Friday, Jun 24, 2011 at 10:47
No, I tried that and it made no difference on steep descents.
I think it's called "hold" because if you press the accelarator it holds the gear you're in without dropping down, to prevent wheelspin.
731786
Follow Up By: steven c1 - Friday, Jun 24, 2011 at 12:30
thanks rob, my email is steven182b@gmail.com. i have upgraded the shocks so im guessing it wont work. thanks for your help, greatly appriciated!!
731795
Follow Up By: Rob! - Monday, Jul 04, 2011 at 14:47
Steven,
I haven't forgotten about your fuse box diagram translation. I couldn't find it on my computer at home, so I'll have to search for it on my archived disks.
Don't worry, I'll get there.
R.
732711
Reply By: Member - Bucky - Friday, Jun 24, 2011 at 11:32
Terano's are basically a left handed Pathfinder.
Have you tried the pathfinder Manual ?
Before you go to great expense, you may find an electronic copy on the Net.
Cheers Bucky
458331
Follow Up By: Rob! - Friday, Jun 24, 2011 at 12:09
What do you mean a "left handed pathfinder?"
731794
Follow Up By: steven c1 - Friday, Jun 24, 2011 at 12:32
i had a pathfinder prior to owning the terrano, and no there not the same, some of the features and body work are similar however.
731796
Follow Up By: Member - Bucky - Friday, Jun 24, 2011 at 15:15
Basically they could be classed as a Pathfinder Version 4/5th
That's what I an getting at
Neighbour across the road had one, and if he needed parts ect, he would always startwith Parthfinder stuff, and 8 times out of 10 he would get what he was after.
They are quiet a good little jigger
A real shame they never really took off here.
Cheers Bucky
731806
Follow Up By: Rob! - Friday, Jun 24, 2011 at 15:31
Right. Body parts from the Pathfinder and engine parts from the d21 navara is what always worked for me.
They didn't take off because our government stopped
grey imports to protect the local car dealers.
731809
Follow Up By: Member - Bucky - Friday, Jun 24, 2011 at 20:18
Cheers Rob !
731833
