Caravan cooktop
Submitted: Wednesday, Jun 29, 2011 at 16:05
Seagecko
Hi All,
I'm about to upgrade the old van a bit, and was wondering why gas cooktops for caravans are so much dearer than domestic ones.
Does anyone know of the physical differences, and are there any legal reasons why I can't use a domestic cooktop which is manufactured to run on LPG?
And yes, (before I get jumped on by the self-appointed regulatory police) I will be using a licensed gas fitter.
Seagecko.
Reply By: Member - Michael P (QLD) - Wednesday, Jun 29, 2011 at 16:24
Seagecko,
Possibly due to safety shut-off when lid closed or partially, safety cut-out on burners. Probably more so to lower manufacturing volume.
Mike.
458770
Reply By: member-PradoMad - Wednesday, Jun 29, 2011 at 19:10
Why not install one of these?
Works wonders.
sometimes available from Kmart or ebay
watch this:
http://www.youtube.com/watch?v=Z-hdIlNIMq8
JS.
Image Could Not Be Found
458793
Follow Up By: Nomadic Navara - Wednesday, Jun 29, 2011 at 22:54
Possibly because it is designed to run off high pressure gas - ie direct from the cylinder like most
camping stoves. You need a low pressure one to run on a gas system in a van. Does it run directly from a cylinder without a regulator?
732366
Reply By: Nomadic Navara - Wednesday, Jun 29, 2011 at 22:56
I see no reason why, apart from the fact that they are larger. Your gas fitter should be full bottle on your question.
458830
