Pajero Vibration
Submitted: Monday, Jul 04, 2011 at 10:09
Stephen R2
Hi Guys,
When my Pajero (2002 with 90k km) is stationary it occasionally develops a shake. On a long drive on the weekend as I went up a
hill-climb a much more serious shake would develop and only go away when I eased off accelerator. It seems to occur when it is gear change time (it is auto). Any ideas what my likely problem is? Cheers & thanks.
Reply By: snoopyone - Monday, Jul 04, 2011 at 10:19
Is it a petrol or a Diesel Makes a hell of a difference in the replies you will get.
More info = better answers
459134
Reply By: Stephen R2 - Monday, Jul 04, 2011 at 10:22
Thanks very much - It is a petrol vehicle.
459136
Reply By: Peter McG (Member, Melbourne) - Monday, Jul 04, 2011 at 15:00
Check the engine mounts.
459154
Reply By: Glenn_cot - Monday, Jul 04, 2011 at 15:28
Check the Transmission mount I believe it has some sort of harmonic counter balance on it.
459160
Reply By: snoopyone - Monday, Jul 04, 2011 at 17:46
Plugs or leads could be stuffed and breaking down under load.
Had a car once that did that and got out one night and looked under bonnet.
Was a fireworks display as plug leads were shorting onto a heater hose fitting coming out of the block.
459175
Reply By: Member - Ralph K (WA) - Monday, Jul 04, 2011 at 17:50
Possible electrics breaking down under load but if not, get trannie checked.
459177
Reply By: kiwicol - Tuesday, Jul 05, 2011 at 15:53
check fan blades on cooling fan,
Col
459236
Reply By: Stephen R2 - Tuesday, Jul 12, 2011 at 09:24
Thanks to everybody who assisted and gave suggestions it was very much appreciated and reflects what a great community you are. As it turned out it was an electricals issue. #6 cylinder was not functioning due to a cracked spark plug and lead arcing out. The prob was exacerbated by an oil leak from the cover gasket. HT leads were replaced etc.
Thanks again.
459720
