Honda extended run fuel caps
Submitted: Thursday, Jul 28, 2011 at 21:52
ThreadID: 87843 Views:2905 Replies:5 FollowUps:0
Has anyone used these. They look fairly simple .
Cheers Wilko
Site Link
Reply By: Motherhen - Friday, Jul 29, 2011 at 00:47
Hi Wilko
I read about them on a forum a couple of times before - i think it was here but i may be wrong about that.
AnswerID: 461202
Reply By: Motherhen - Friday, Jul 29, 2011 at 00:53
Try this previous thread for starters Wilko
Mh
AnswerID: 461203
Reply By: Wilko (Parkes NSW) - Friday, Jul 29, 2011 at 09:21
Thanks MH,
I knew youd be on the ball ; )
Cheers Wilko
AnswerID: 461219
Reply By: member - mazcan - Friday, Jul 29, 2011 at 13:16
hi wilko
thats a great invention /and the system will work and you should be able to turn on the fuel flow from the auxillary tank before the gen is started providng there is no excess fuel return pipe from the genie to main tank from a pump fed system
which would require a return line to auxcillary tank to stop build up of excess fuel in main tank
which could/might cause back pressure in main tank
but if the fuel from the main and auxillary tank is only drawn by vacumm it will start drawing from auxtank as soon as the genny is started and use the fuel in the main tank last
i had a honda gen a few years ago and cant recall if it had an excess fuel return line from carby to tank but provided they are only vacumm fed this will not be an issue
if i had a genny i would buy one of those units
not trying to confuse anyone just my thoughts based on many years of dabbling with these sorts of things on tractors and 4wd's during and since my farm life
cheers barry
AnswerID: 461237
Reply By: Mrbrush - Friday, Jul 29, 2011 at 19:53
Unless you wanted to run it right through the night, why would you bother ,
how hard is it to top up the tank every few hours ?
Jesus bloody christ
AnswerID: 461285
