Single draw for a 4X4 - does anyone make one?
Submitted: Wednesday, Aug 03, 2011 at 09:34
ThreadID: 88240 Views:4519 Replies:7 FollowUps:7
I am looking for a single draw that will take up about half the width of the freight compartment of my Jackaroo. All I have been able to find in a web search is the DIY units from Offroad Systems where a single draw looks as though it would do the job, with a bit of improvisation.
And can anyone tell me? How are these units normally attached to the vehicle? Simply bolted through the floor?
Thanks.
Kevin
Kevin
2019 Mitsubishi Cross
Reply By: MrBitchi (QLD) - Wednesday, Aug 03, 2011 at 09:53
Have a look at Black Widow. They have a range of different setups.
AnswerID: 461680
Reply By: i'machocoholic - Wednesday, Aug 03, 2011 at 11:39
Try Luke from Drifta, his gear is top notch...we love the stuff he has made for us. Also very reasonable.
www.drifta.com.au
AnswerID: 461688
Reply By: Member - DAZA (QLD) - Wednesday, Aug 03, 2011 at 13:04
G/Day Kevin
Contact (Best Off Road) Jim is a Exploroz Member he manufactures Draws.
Also gives members discounts.
AnswerID: 461698
Follow Up By: Wilko (Parkes NSW) - Wednesday, Aug 03, 2011 at 19:47
Hi Kevin,
I secound Jim from Best off road. He designed mine to my specs. If it can be designed I'd say he can make it.
Good quality good service and personally designed, it worked for me.
Cheers Wilko
FollowupID: 735447
Reply By: Member - Oldbaz. NSW. - Wednesday, Aug 03, 2011 at 13:19
G'day Kevin, there is a two drawer set on Ebay for a Jackaroo, that may be suitable for
modification. At Tewantin, QLD, 2 days to go, currently at $180. I have no association
, just a Jack owner always looking for toys. cheers....oldbaz.
AnswerID: 461700
Follow Up By: Member - Kevin S (QLD) - Wednesday, Aug 03, 2011 at 19:48
Found it and added to my watch list although it is much bigger than I want. But if the price is right it still has possibilities.
Thanks,
Kevin
Kevin
FollowupID: 735448
Reply By: Member - Mark G Gulmarrad - Wednesday, Aug 03, 2011 at 19:13
Kevin
mate why not have a crack at making your own?
i made myself a full set.......after a little thought the plan will come to you and away you go.
here's mine i made :-)
navara drawers
AnswerID: 461739
Follow Up By: Member - Kevin S (QLD) - Wednesday, Aug 03, 2011 at 19:46
Mark, you did well. Good set up. Yes, building my own is an option. My biggest obstacle is that I can't weld but I suppose I can get that done for me fairly easily.
Thanks for the pics.
Kevin
Kevin
FollowupID: 735446
Follow Up By: Member - Mark G Gulmarrad - Wednesday, Aug 03, 2011 at 20:22
Kevin
there isnt a single weld in those drawers....its aluminum and the connectors are plastic inserts.
FollowupID: 735452
Follow Up By: Member - Kevin S (QLD) - Wednesday, Aug 03, 2011 at 20:48
With joints glued and screwed? I've had a closer look at your pics and see what you mean. Looks like an effective method. Thanks.
Kevin
Kevin
FollowupID: 735455
Follow Up By: Member - Mark G Gulmarrad - Wednesday, Aug 03, 2011 at 20:57
Kevin
the joints are a tight fit.i applied some crc to the plastic joiners and carefully tapped them in with a hammer. you could put a pop rivit into them but i found there wasnt any need to,as they havent worked their way out and they have been in there for some time now.
FollowupID: 735457
Reply By: Member - Kevin S (QLD) - Wednesday, Aug 03, 2011 at 19:56
Interesting to note that a blog has popped up on the home page today for a member named Draw Slide who have a range of sliding products including a range of single draws that can be grouped into almost any configuration that you may want.
The options keep increasing. Talk about a mine of information.
Kevin
Kevin
AnswerID: 461746
Reply By: Drawer Slide - Wednesday, Aug 03, 2011 at 19:59
Hi Kevin,
You can try my website www.drawerslide.com.au
I can supply you the slides/handles and hardware if you want to make it yourself or I can supply you a pre-fabricated drawer system which would be $599.00 Inc GST per drawer unit delivered to all capital cities or close to Australia wide.
Image Could Not Be Found Image Could Not Be Found
AnswerID: 461747
Follow Up By: Member - Kevin S (QLD) - Wednesday, Aug 03, 2011 at 20:13
I checked your web site from the blog before I did the above post. I'll get in touch directly in a day or so with some questions.
Thanks for your post.
Kevin
Kevin
FollowupID: 735450
