Uluru to Brisbane
Submitted: Sunday, Aug 14, 2011 at 19:52
ThreadID: 88472 Views:3093 Replies:4 FollowUps:1
Hi ,I have tried to look at my limited maps that I have,without sucess,to see if there is a reasonably direct route from Uluru to Brisbane.Can someone plese tell me the best way and the condition of the road,I am thinking of doing the trip from Perth to Brisbane via the middle.
thanks
Dean
Reply By: p_marns - Sunday, Aug 14, 2011 at 21:48
Hi dean, I am going from brisbane to uluru in a few weeks and i am heading straight west to birdsville then north to boulia then west again to alice via the plenty hwy. not sure if its the quickest but its reasonably direct.
AnswerID: 462618
Follow Up By: Bob Y. - Qld - Sunday, Aug 14, 2011 at 22:12
To go via Windorah, then up to Bedourie would be shorter again, and probably the most direct route, using the better roads.
If you like bitumen, then go via Longreach, Winton and Boulia. But that's quite a bit further.
Bob.
FollowupID: 736419
Reply By: Member Al (Sunshine Coast) - Sunday, Aug 14, 2011 at 22:21
Dean, Your problem is that you have both the Simpson Desert and Lake Eyre in your path.
Other than going across the Simpson Desert track via Birdsville, the Plenty/Donohue Highway starting from just north of Alice Springs and via Boulia is the most direct route. The road is unsealed but formed and with loose stones but OK for a 4WD driven to conditions. It would be rather rough on a 2WD sedan.
Otherwise you would need to go South to Lyndhurst and then up to Innamincka before heading West to Brisbane. Again, some unsealed roads but of good condition.
To stay on sealed bitumen roads you would need to go South to Port Augusta then head through Broken Hill and Cobar to Brisbane. A long route.
AnswerID: 462622
Reply By: Dean L - Sunday, Aug 14, 2011 at 22:42
Thanks for the reply's,I have a 4.2 turbo patrol ,so I don't mind some off road stuff.I will try and track down a good map to work out the distance
Dean
AnswerID: 462624
Reply By: wizzer73 - Monday, Aug 15, 2011 at 20:49
outback hwy
What about the outback hwy? Or is this too far north of brissy
wizzer
AnswerID: 462690
