Review: Camping Lights
My Article Rating: My Rating 3/5
I came across some LED lights using cree technology.They come as a floodlight or torch. I use 1 floodlight to illuminate my camp-site. It is 10watts and rated at 450 lumen's. It only uses .9 of an amp.No heat and cost about $40.00 on eBay. The best light I have seen. I am currently looking at a 20 watt light which also uses .9 of an amp
Reply By: Geoff (Newcastle, NSW) - Thursday, Aug 18, 2011 at 19:47
Link?
Geoff,
AnswerID: 462896
Follow Up By: windmilljack - Thursday, Aug 18, 2011 at 21:16
http://www.ebay.com.au/itm/10W-High-Powered-LED-Flood-Light-Lamp-12V-White-800LM-/320740417863?pt=AU_Lighting_Fans&hash=item4aad9e6147#ht_936wt_905
Not good at this stuff but am learning. These are in hong kong. I have found them in OZ, They will come up as 240v ac sometimes but if you contact the seller they can do them in 12 0r 24 volt dc. Ask for white as they come in warm white as well which is not as bright. Also type in cree torches and there are some great headlamps. Hope I have helped. Bloody good lights
FollowupID: 736721
Follow Up By: CSeaJay - Friday, Aug 19, 2011 at 09:16
The link working but the item has been removed!
Can you locate the item?
CJ
FollowupID: 736747
Follow Up By: windmilljack - Friday, Aug 19, 2011 at 18:53
http://www.ebay.com.au/itm/10W-High-Powered-LED-Flood-Light-Lamp-12V-White-800LM-/320740417863?pt=AU_Lighting_Fans&hash=item4aad9e6147#ht_1015wt_903
hi this is another light i found. just type in led floodlights .their description is 10W High Powered LED Flood Light Lamp 12V White 800LM. some come up as 240v but if you contact the seller they can supply 12volt
FollowupID: 736814
Follow Up By: windmilljack - Friday, Aug 19, 2011 at 18:57
still learnin mate sorry. paste the above into google it should work
FollowupID: 736816
Follow Up By: Crackles - Friday, Aug 19, 2011 at 19:16
TRY HERE
FollowupID: 736822
Reply By: Polaris - Thursday, Aug 18, 2011 at 20:04
Thanks for that WMJ - a link would be nice.
AnswerID: 462900
Reply By: olcoolone - Thursday, Aug 18, 2011 at 21:16
I would be a bit concerned about someone advertising a 20 watt light that only uses .9 of an amp.
If it's 20 watts it has to use 20 watts of energy, it might be advertising hype and they may be talking about pulse width modulated drivers controlling a 20 watt light using .9 amps.... meaning they are switching the signal on and off very quickly to obtain a theoretical .9 amps.
I can show you a true 10 watt light that out performs a true 30 watt light, the difference is quality and 10 times more expensive.
Be cautious of the advertising hype.
AnswerID: 462908
Follow Up By: windmilljack - Thursday, Aug 18, 2011 at 21:48
I am not up with the electronic stuff but I know that the lights are very bright and use little power. I have a small 7ah battery and have run one of these 10 watt lights for 5 hours with no problems. I think you are right about the pulsing and I can understand you being sceptical. I have spent lots of money on lighting as I am old and my eyes are going quicker than my hair. I have used these for 2 years and am extremely happy with them. One of these lights will light up a large area with good crisp light. The LED is a square looking globe about a square centimeter in size.
FollowupID: 736725
Reply By: desray (WA - Friday, Aug 19, 2011 at 10:03
Item number: 320740417863 ?????
AnswerID: 462947
Reply By: Crackles - Friday, Aug 19, 2011 at 19:22
"I am currently looking at a 20 watt light which also uses .9 of an amp"
Unless they have worked out a way to get around the laws of physics a 20W light will use a touch over 1.6Amps @ 12 volts.
EG: Watts divided by Volts equals Amps.
Cheer Craig...........
AnswerID: 463003
Reply By: Member - Rocker (NSW) - Friday, Aug 19, 2011 at 19:45
I'm a visual type, where's the pics?
Looking for some good lighting as well
AnswerID: 463006
