Question: Classifieds
Submitted: Saturday, Aug 27, 2011 at 09:38
ThreadID: 88708 Views:2580 Replies:4 FollowUps:8
My electrolux rm2310 has stopped working on 12 volt any ideas would it be the switch.I am also looking for window lock on 94 viscount gazelle it has sliding windows.
Reply By: Notso - Saturday, Aug 27, 2011 at 10:40
Are you getting 12 volt power to the fridge?, does the indicator light come on when you switch it to 12 volt? I think that model had a light in the actual switch.
AnswerID: 463626
Follow Up By: Graeme A - Saturday, Aug 27, 2011 at 11:32
no there is no light in the switch there is 12 volt power at back of fridge.
FollowupID: 737457
Reply By: grime 54 - Saturday, Aug 27, 2011 at 11:28
Could be 12v heating element burnt out.
AnswerID: 463630
Follow Up By: Graeme A - Saturday, Aug 27, 2011 at 11:35
do you have to pull the fridge out to get at heating element & switch.
FollowupID: 737458
Follow Up By: grime 54 - Saturday, Aug 27, 2011 at 11:43
Should be able to check element from outside of van through vent grill but would probably have to remove fridge to replace same.
FollowupID: 737459
Reply By: Notso - Saturday, Aug 27, 2011 at 12:02
Sounds like the element may have gone, Did you check for voltage at the element? Can you get to the switch at the rear and see if there is power getting to the switch and power going through it when it's turned on, also check what voltage you have on the downstream side of the switch when it is turned on. There is a possibility that not enough volts are getting to the unit. But it must be turned on when you check the voltage as you won't know if there is a high resistance somewhere until you put it under load, if the voltage drops below around 11.5 or 12 volts that may be your problem
AnswerID: 463632
Follow Up By: Graeme A - Sunday, Aug 28, 2011 at 11:15
checked element wrks well but is not getting power to it sparky seems to think thermostat as there is no power there but i think its the switch as it has to send the signal for anything to work.
FollowupID: 737537
Follow Up By: Notso - Sunday, Aug 28, 2011 at 11:29
The 12 volt system doesn't use a thermostat as far as I know. When you turn it on it's on permanently.
FollowupID: 737540
Follow Up By: Graeme A - Sunday, Aug 28, 2011 at 19:34
by the manual i downloaded 12v does work of the same thermostat
FollowupID: 737592
Reply By: Hairs & Fysh - Saturday, Aug 27, 2011 at 15:00
Hi Graeme,
Is this of any help to you?
Dometic@ MANUALREFRIGERATORS
AnswerID: 463643
Follow Up By: Graeme A - Sunday, Aug 28, 2011 at 19:36
have the manual already
FollowupID: 737593
Follow Up By: Hairs & Fysh - Sunday, Aug 28, 2011 at 19:43
No worries,
Hope you get it sorted.
FollowupID: 737596
