nissan gu emobilizer
Submitted: Tuesday, Sep 06, 2011 at 21:07
ThreadID: 88874 Views:1758 Replies:1 FollowUps:5
The dash red immobiliser blinking light is now on permanently & occasionally the vehicle will not start as if the immobiliser/key is no longer programmed
Question: do the keys loose there program & is the light a warning or do I just have a intermittent fault ???? any ideas out there
regards Vince
Reply By: Member - Troll 81 (QLD) - Wednesday, Sep 07, 2011 at 10:50
If it's lost its code then it won't work at all. Check your key and make sure the little red chip still in there looks like a little button.
AnswerID: 464421
Follow Up By: Member - Vince M (NSW) - Wednesday, Sep 07, 2011 at 14:30
non of the keys have a red chip but they all work & then out of the blue the red light comes on & stays on whilst driving every thing works & then stop & it might start or not that's the problem
FollowupID: 738376
Follow Up By: Member - Troll 81 (QLD) - Wednesday, Sep 07, 2011 at 14:40
Odd every Patrol key I have ever seen had a little chip in them that hold the code. My spare key doesn't have the chip and it will start the car but it will die within seconds.
In yours the chip migt be inside the actual key. Mine is from a 99 GU so yours might be different.
FollowupID: 738378
Follow Up By: Member - Troll 81 (QLD) - Wednesday, Sep 07, 2011 at 14:45
I take it it's actually turning over but just not fireing?
FollowupID: 738379
Follow Up By: Member - Vince M (NSW) - Wednesday, Sep 07, 2011 at 15:59
its a 2004 4.2 there is a sealed section in the key Non removable where the program is & yes it turns over & it will start sometimes & not other times & this happens on all 3 keys I have, it all started at the same time the dash light just came on & stayed on
I will have to find how to disconnect the immobilizer
FollowupID: 738384
Follow Up By: Member - Christopher P (NSW) - Saturday, Sep 10, 2011 at 16:10
in the manual it says if you see light constant flashing head straight to dealer as the immobiliser has failed.....
FollowupID: 738638
