Galaxy Southern Cross series 4 filling water tanks
Submitted: Monday, Sep 12, 2011 at 20:30
ThreadID: 88987 Views:4507 Replies:4 FollowUps:4
When filling the 2x 60 lt water tanks under the van the water keeps spitting back out of the filler hole. Becomes almost impossible to fill after tanks are half full. Vent does not appear to be blocked as i can blow through vent hose. The 1in filler inlets are situated half way up the tanks, is this the normal location for them. Any comments or suggestions would be appreciated.
Regards peter
Reply By: Member - reggy 2 (VIC) - Monday, Sep 12, 2011 at 21:30
HI Peter
Check that the vent is hooked up right as my van was not even connected or maybe you turn on tap too fast do you open both caps at the same time I think
the tanks should be linked together
hope this helps cheers
AnswerID: 464853
Reply By: willawa - Monday, Sep 12, 2011 at 21:36
do the tanks have an outlet/drain at the base?
if try filling from them as it lets the air escape out the fillers.
we used to do this with our first CT>
was also a quicker way of filling the tank.
chers
ED
AnswerID: 464855
Follow Up By: awill4x4 - Tuesday, Sep 13, 2011 at 19:37
I've got an 03 Galaxy Southern Cross 16'6" and have the same problems filling the tank and I use exactly the same procedure as Ed.
You just need to be careful fitting the hose as the plastic fitting is a bit fragile but filling the tank takes half the time.
Regards Andrew.
FollowupID: 738849
Reply By: Robtbob NSW - Monday, Sep 12, 2011 at 22:04
I have a Galaxy too and found it hard to fill. I used to fill the tank with the hose pressure on medium and it would blow back. So I reduced the pressure to slow and went for a walk and it filled it up no probs. Good luck.
AnswerID: 464859
Reply By: Member - John & Sally W (NSW) - Tuesday, Sep 13, 2011 at 08:21
Hi Peter,
We also had trouble filling our Coromal tanks. This problem has also been discussed on a couple of other forums. We learnt from others to feed the hose down passed the breather hole and then fill normally. Some bloke on the caravanners forum has designed a thin plastic hose and clamp that attaches to normal hole so that there is still enough room for breathing and water backing up when tanks are full, but we were concerned that if this extension came off down the filler tube that there would be a lot more trouble. We use no extra pressure, just make sure there are no kinks in tubes first.
Sally
AnswerID: 464875
Follow Up By: Member - John & Sally W (NSW) - Tuesday, Sep 13, 2011 at 08:22
Sorry sould say normal hose
FollowupID: 738816
Follow Up By: BJ - Wednesday, Sep 14, 2011 at 08:46
Same issue with Goldstream. I cut a 12" length of 1/2" clear plastic hose and fitted usual hose connectors to connect to the filling hose.
The plastic is softer and slides further down the filler tube. no problems since.
FollowupID: 738887
Follow Up By: Peter G11 - Monday, Sep 19, 2011 at 17:16
Thank you all for those comments and suggestions on my water tanks will give them a go and see what happens
FollowupID: 739501
