Coleman fuel-?still available
Submitted: Saturday, Sep 17, 2011 at 16:31
oz doc
Hi all, is anyone else having trouble finding Coleman
Fuel? None of the
camping outlets here in Bunbury have any supplies. Ta , doc.
Reply By: Rangiephil - Saturday, Sep 17, 2011 at 16:50
Isn't Shellite the same stuff?
Regards Philip A
465281
Reply By: Member - MIKE.G - Saturday, Sep 17, 2011 at 17:01
HI OZ DOC - SHELLITE IS THE SAME STUFF. BUNNINGS STOCK SHELLITE IN 5LT AND 1LT BOTTLES. ABOUT $27.00 FOR 5LT. SOME HOME HARDWARE, MITRE 10 AND COUNTRY
IGA SUPERMARKETS ALSO CARRY IT.
WHITE SPIRIT IS NOT THE SAME THING AND WILL NOT WORK IN COLEMAN
FUEL APPLIANCES.
IF YOU ARE USING A QUANTITY, YOUR LOCAL SHELL DEALER CAN GET IT IN 20LT DRUMS. GOOD LUCK.
465283
Follow Up By: oz doc - Saturday, Sep 17, 2011 at 17:42
Thanks guys but I am led to believe Shellite is not the same stuff. Apparently Coleman
Fuel has additives in which help prevent things gumming up. When we initially bought the lamp many years ago we ran it on Shellite and pretty soon had a problem with the regulator. Had it serviced at a
camping store in Cannington and the chap there advised stick to the Coleman
Fuel. Have done so ever since without any problems. Coleman no longer make parts for this
fuel light so want to keep it going as long as possible. Went into army surplus store today and they said haven't been able to get the coleman
fuel lately so was wondering did anyone know who has supplies. Thanks for your replies. doc.
739286
Follow Up By: derraux - Saturday, Sep 17, 2011 at 18:04
Coleman are in the process of repackaging thier
fuel and it will soon be available. People don't normally have trouble with shellite. Having problems with it shortly after buying it could have been from oil in the generator form manufacturing. I assume this is what you mean by regulator. New lamps need a good initilal burn to make sure anything that is in there from new is burnt out. Or it could have just been one of those thing's i have seen shelite go off and not burn but no gum up. How old is your lamp most generators for coleman lamps are available.
Good luck
Derek
739289
Follow Up By: oz doc - Saturday, Sep 17, 2011 at 18:09
HI and thanks derraux, our lamp is approximately 10 years old. We used it for about 2 years before having trouble with the generator. I did a search on the coleman website for a new generator and rubber seal- no longer available. I have pulled the pump mechanism apart and given it a clean and lube. Hoping with some coleman
fuel it will go for a bit longer but if not I guess we have had a good run out of it.Thanks, doc.
739291
Follow Up By: derraux - Saturday, Sep 17, 2011 at 18:17
Oz Doc
What lamp is it whitout plugging the buisness i possible have a generator for your lamp i have alot of older generators and i am in
perth. pump cups are still available and there is not alot more to them.
Derek
739293
Follow Up By: oz doc - Saturday, Sep 17, 2011 at 18:24
Thanks Derek it is 282-700T- the single mantle model. I would love to have a new generator and a new pump cup if you have one. The pump mechanism seemed to come apart last time I used it. Took it apart and looks like it had just unscrewed from the base for some reason. Anyway, the pump cup was a bit tired but came good with a clean and a drop of oil. The pump mechanism is working again but a bit noisy and not too smooth. The lamp is tending to surge and flare up a bit but only has a drop of
fuel in it at the moment. I was hoping to buy some coleman
fuel and give it a good run before deciding if it is salvagable or not. If I could replace the pump cup and generatory I think it will be fine. Ta, doc.
739295
Follow Up By: snoopyone - Saturday, Sep 17, 2011 at 18:26
I have a brand new Coleman light sitting in the garage Bought it for a trip and never took it. Paid $85 for it
Unpacked it and then put it back in the box where it resides to this day.
739296
Follow Up By: derraux - Saturday, Sep 17, 2011 at 18:27
Oz Doc
Give me a call
Go
Camping 08 9344 6252
Derek
739297
Reply By: Tenpounder - Saturday, Sep 17, 2011 at 17:55
Hi there. I just looked on the Coleman website, and they show the following sources in Bunbury for Coleman
fuel.
BUNBURY ARMY SURPLUS
Shop 8, Bunbury Boulevarde, Prinsep St BUNBURY WA 6230
Phone: 0897212077
Web:
BUNBURY 6230 COMPLEAT ANGLER &
CAMPING WORLD BUNBURY
COMPLEAT ANGLER &
4 Mervyn St, Homemaker Centre BUNBURY WA 6230
Phone: 0897919306
Web: www.campingworld.com.au
BUNBURY 6230 GETAWAY OUTDOORS BUNBURY
39 STRICKLAND STREET BUNBURY WA 6230
Phone: 0897912828
Web: www.getawayoutdoors.com.au
BUNBURY 6230 BCF BUNBURY
Does this help?
465284
Follow Up By: oz doc - Saturday, Sep 17, 2011 at 18:05
Hi Tenpounder- went into every one of these outlets today and no one had any coleman
fuel. Army surplus said they ordered it but wasn't supplied. I'm wondering if Coleman are discontinuing it or have production problem. doc.
739290
Follow Up By: Member - Christopher P (NSW) - Sunday, Sep 18, 2011 at 16:27
bunnings and bcf should have that as
well. haven't looked for anywhere near you you.
739405
Reply By: Bushranger1 - Saturday, Sep 17, 2011 at 20:51
Been using Shellite for near on 20 yrs in my Coleman single & twin burner stoves without any problems at all.
Bought a Coleman duel
fuel light about 6 yrs ago & no probs using Shellite in that too.
Stu
465292
Reply By: Member -Pinko (NSW) - Saturday, Sep 17, 2011 at 21:46
I have been using a product made by GSB performance chemicals for a few years.
The chemical name is K55 and otherwise known as 'shellite'
I buy it in an industrial estate outlet at Labrador
Gold Coast in a 20lt drum which lasts me about 2.5 years.
The last drum worked out at about $4.50 per litre.
It may pay to email GSB and find an outlet.
Stan
465302
Reply By: Member - Krakka - Saturday, Sep 17, 2011 at 22:07
Caltex make a product that we have used exclusively for 15yrs, have never replaced a generator in two stoves and a light.
It is called Solvent 143. About $80.00 for a 20lt drum.
465309
Follow Up By: Pete Jackman (SA) - Saturday, Sep 24, 2011 at 02:01
We use 143 in our stove and 282lantern with no issues. Like the price too.
Pete
739885
Reply By: oz doc - Sunday, Sep 18, 2011 at 17:43
Thanks to all whom replied. Sounds like the Coleman
fuel stocks will be available again soon, and in the meantime shellite is just as good(despite my earlier beliefs). Derek has kindly offered to supply me with a new generator and pump assembly which should sort things out nicely. Thanks again folks, doc.
465389
Reply By: Member - MIKE.G - Sunday, Sep 18, 2011 at 18:52
I worked for COLEMAN for ten years when the first set up in Aus (1978) and COLEMAN
FUEL as you know it now was not available as we could not import it. We sent samples of SHELLITE to the USA and it is compatible with their
fuel and has no build up in the generators of either lanterns or stoves. BP also had a similar product they packaged in 5 lt cans but due to low demand took it off the market. Hope this clears up any misunderstandings. Shellite is fine. Cheers, Mike
465397
