fuel filters and pumps
Submitted: Sunday, Sep 18, 2011 at 14:30
ThreadID: 89097 Views:2470 Replies:5 FollowUps:4
I have just fitted a 2 micron fuel filter to my 07 hilux, now it has trouble starting when cold, is this because of the filter or is the fuel pump not up to it
any help would be appreciated
Reply By: Member - Tony H (touring oz) - Sunday, Sep 18, 2011 at 15:07
Petrol or diesel?
AnswerID: 465368
Reply By: member - mazcan - Sunday, Sep 18, 2011 at 15:20
hi ty c
i take for granted you are refering to a diesel??????? if so
my opinion is there is still air in the system
bleed it
make sure there is no air in the top of the filter housing and crack the injector nuts open one at a time while its idling and bleed the system until there are no air bubbles present
in most cases this will fix the problem even just a small amount of air in the diesel system will make it hard to cold start it
cheers barry
AnswerID: 465370
Follow Up By: den57 - Sunday, Sep 18, 2011 at 16:04
Just a word of caution, if you are going to bleed a common rail diesel, that is any diesel post mid 2007, be very carefull. The pressure in the line going to the injector can be deadly. Not talking from experience but have been told by enough people not to contemplate cracking a injector line on a common rail motor. They work on pressures that are approx 6 times higher than the diesels of old and have been told it has the pressure to slice a finger off or inject diesel into the flesh.
Regards the problem of hard to start, i have a landcruiser and was told not to put an additional filter of less than 30 micron on as it will restrict fuel flowing thru the pump and therefore cooling of the pump. May be a problem in not being able to pass enough fuel, try bypassing the new filter and see if that eliminates the problem
I was interested in trying to eliminate water and chunky bits getting thru to the main fuel filter. To date have on two occasions found droplets of water in the glass inspection bowl.
Den
FollowupID: 739403
Follow Up By: olcoolone - Sunday, Sep 18, 2011 at 17:33
Yes 20000 psi is enough to take a finger off, NEVER CRACK LINES ON A CRD ENGINE.
FollowupID: 739409
Reply By: Roughasguts - Sunday, Sep 18, 2011 at 16:14
Hell a 2 micron fuel filter is just about already blocked!
Put the same filter on that came off it.
Cheers.
AnswerID: 465373
Follow Up By: olcoolone - Monday, Sep 19, 2011 at 08:51
2 micron.
FollowupID: 739471
Reply By: Member -Pinko (NSW) - Sunday, Sep 18, 2011 at 16:33
If you are adding an extra filter as a water trap and therefore it is fitted before the original equipment and the motor is common rail there must be no restriction, as said before no less than 30 micron.
You might wish to look at water watch
I'm waitng for mine to come in the post.
Stan
AnswerID: 465378
Follow Up By: Member -Pinko (NSW) - Sunday, Sep 18, 2011 at 16:37
That didn't work
www.reponsiveengineering.com.au
FollowupID: 739406
Reply By: ty c - Sunday, Sep 25, 2011 at 14:09
thanks for all the advice, turns out just a bit of air in the system
AnswerID: 466004
