Steering slop....!
Submitted: Tuesday, Sep 27, 2011 at 08:45
ThreadID: 89261 Views:2346 Replies:2 FollowUps:1
Hi All,
I have a 105 series Toyota Landcruiser, that has slop in the steering. When I move the steering, there is about 20 degrees slop. It appears not to be any links.
Any way this can be adjusted out of the steering box?
Reply By: Bandit02 - Tuesday, Sep 27, 2011 at 09:11
This post has been read by the moderation team and has been moderated due to a breach of The Advertising/Self-Promotion Rule .
Forum Moderation Team
AnswerID: 466136
Reply By: Member - Christopher P (NSW) - Tuesday, Sep 27, 2011 at 16:05
if it has a drag link on it then it is in the drag link, my hilux has same amount of slop in it.
they tend to wear out. if you get someone to turn the wheel from left to right far enough and you are looking then you'l see the drag link move before the J arm. you can't just wiggle it and expect to see any movement.
hope this helps.
chris
AnswerID: 466162
Follow Up By: Parso - Tuesday, Sep 27, 2011 at 20:52
Had the same problem with mine and had to replace the whole column.
Not a disaster, but it fixed the problem.
It was wear in the 'buffer'. No problems with the steering ball-joints, etc.
Guest 4WD to the fore again!
Parso
2012 Toyota Landcruiser 200 Series Sahara.
FollowupID: 740272
