Recycle air on 'lux
Submitted: Wednesday, Dec 03, 2003 at 06:27
ThreadID: 8927 Views:2018 Replies:4 FollowUps:0
G'Day all, just wondering, I seem to get a flapping sound from the rear vent when I switch the air to recycle in my Hilux. Before I take it in to Toyota, I was wondering if it's just a normal sound that's in every Hilux?
Reply By: troy - Wednesday, Dec 03, 2003 at 11:29
no i dont have any flapping sounds.
i have a dual cab hilux
AnswerID: 39274
Reply By: Bazza - Wednesday, Dec 03, 2003 at 11:47
G'day Raymound,
Check the ducts, keep switching between mix & recycle air and keep varing the fan speeds. You may dislodge something that mat be stuck in there ... leaves, small sticks ect. ect. Only a thought, but worth a go. Toyota will probably charge heaps to investigate.
Regards,
Bazza.
AnswerID: 39277
Reply By: Member - Bradley- Wednesday, Dec 03, 2003 at 11:50
We have a single cab lux and no noise from outlet flaps . sounds like when you go to recirc and lose cabin positive pressure you are getting some buffetting causing the rubber flap to vibrate oben and closed, just check that you haven't hit in the vent with a gerni causing it to get caught up and not sit flat. You might also have a tray design causing wind to swirl and buffett in behind the cab which can be fixed with some sort of shielding surrounding the outlet valve. Hope this helps, BradMoo... everyone knows what a Jackaroo looks like :-)
AnswerID: 39278
Reply By: Member - Raymond - Wednesday, Dec 03, 2003 at 14:20
Thanks for the replies, I phoned Toyota today and they'll look at it as it's still covered under warranty. Hope they can fix it as sometimes it gets fairly annoying.
AnswerID: 39290
