lifting Jeep
Submitted: Tuesday, Sep 27, 2011 at 22:01
BJ
New to ExploreOz.
We have done a bit around middle OZ with a swag off the side of the car, but have just bought a Goldstream Crown offroad and looking to get a bit more height under our Jeep Grand Cherokee and support for the van. i am about to fit a 40mm lift with an OME kit. Anything i should look out for??
Reply By: Member - Wayne B (NSW) - Tuesday, Sep 27, 2011 at 22:12
BJ
I have seen a few issues with steering vibration (Wheel Wobble) on some of the Jeeps when fitted with lift kit. It usually occurs after hitting pothole which sets off the wobble and you have to stop the vehicle to stop the wobble. Some Patrols also suffered from this problem even without a lift kit.
Off memory Jeep had a
Suspension Lift Kit as standard on one of their models Jeep Could not fix the steering wobble and eventually they removed it altogether from this particular customers vehicle.
I dont think it was a Grand Cherokee though.
Wayne B
466199
Follow Up By: BJ - Tuesday, Sep 27, 2011 at 22:23
Thanks Wayne. we have the 2008 model Jeep GC, and i think later models had a factory system which could lift clearance to 270mm but from reports it gave an awful ride.
We havethe usual problem of usage - probably 80% formed road and 20% bush, but when it gets to bush you want to have the clearance.
740281
Reply By: mikehzz - Tuesday, Sep 27, 2011 at 23:41
I have a Jeep Grand and enquired about a lift. My mechanic said up to 40mm was fine but warned against any more due to the wobble vibration problem mentioned above. He suggested OME. I decided not to bother and will get a rear locker instead. Cheers, Mike
466206
Follow Up By: olcoolone - Wednesday, Sep 28, 2011 at 08:25
A
suspension lift is different to a rear locker, I know what I would have first..... a
suspension lift will get you into more areas then a locker.
740296
Follow Up By: mikehzz - Wednesday, Sep 28, 2011 at 08:36
Yes it read wrong using the word instead. I was going to get both but settled on just the locker. However, personally I believe a locker is of more use to me. My Jeep has been stuck in
places my Freelander 2 has no trouble with due to the FL2's amazing terrain system that acts like twin lockers. The Jeep has open diffs and gets embarrassed every now and then even though it has more clearance than the FL2. Each to his own...I can feel a new thread coming on...What would you prefer a locker or a lift? :-) Cheers, Mike
740297
Reply By: Bill BD - Wednesday, Sep 28, 2011 at 16:31
I would post your question at ozjeep. Lots of jeep knowledge there.
http://www.ausjeepoffroad.com/forum/index.php
466269
Follow Up By: BJ - Wednesday, Sep 28, 2011 at 19:17
Thans Bill good call.
and thanks Mike HZZ re the 40mm comment. interesting feedback today from ARB that OME standard lift kit is 50mm front and 55 back which seems to go against your mechanic's thoughts. I quizzed ARB and they said they had done all the testing and it was fine.
i am going height first because on several trips to Fraser the Jeep dragged its a... through the sand on mounded tracks.
740361
Reply By: Member - Michael M (QLD) - Wednesday, Sep 28, 2011 at 20:51
hi BJ,give Stuart a ring at CRDSTU Suspensions,he is a very good Jeep
Suspension Specialist 0413860777 i have been to the Cape and across the Gulf towing a camper with his lift and have found his lift way better then the big name brands,i have a WH Grand that had a OME kit.
466293
Follow Up By: BJ - Wednesday, Sep 28, 2011 at 21:08
Thanks Michael, is he around SEQ? i am on Sunshine Coast
740380
Follow Up By: BJ - Thursday, Sep 29, 2011 at 09:40
Hi Michael, spoke to Stuart. He uses King springs so quality is good. Meeting him next week. Thanks for the pointer.
740401
Reply By: Member - Michael M (QLD) - Thursday, Sep 29, 2011 at 19:54
Glad to be of help,you will find Stu a very geniune and down to earth bloke
466343
