How do you remove parts of a Plot File
Submitted: Saturday, Oct 01, 2011 at 23:38
Member - Wayne B (NSW)
Hi all
I have downloaded a user trek however it has several straight lines joining sections of the trek. These lines are not part of the route but are usually a line drawn from an overnight stop to the end of the trek. I have tried removing Plot Points but the line simply moves to the next Point
How can I remove these unwanted lines without destroying the actual rout.
Below is the Trek I down loaded and you will see at the western end the line I am talking about.
Kulgera - Warakurna
[Route] Distance: 650.35km Points: 1751 Recorded: Dec 2004
From
Kulgera to Warakurna (Giles)....
ID: 195 Submitted By: ExplorOz - David & Michelle
Thank you
Wayne B
Reply By: get outmore - Sunday, Oct 02, 2011 at 03:36
I get them sometimes and usually open up the plot in notepad
and go through and find the errant line
its usally easy to spot as its the first one for a new day and when compared to the others you can see its got wonky digits
just a mattar of deleting it
466534
Reply By: The Explorer - Sunday, Oct 02, 2011 at 12:52
Hello Wayne
Assume you are using OziExplorer?
In Ozi the issue is caused by the track not conatinng "Section" info i.e track file only contains one "section" and any gaps in the actual track recording are not identified as being a new section....so simple matter of using inbuilt Oziexplorer Split Track function..which splits the track at a certain point and creates a new section not joined by a line to the previous section.
Load the track file and then open "track control" (8th icon along top of screen).
Select "show track list" (4th icon along second row of icons).
Find the point at which you want to split the track - select a point then cycle through the list to the point at which you want to split the track (in your case the point at the exact end (or start) of the offending "line" - red bullseye on screen provides guide to where you are at.
When you have the correct point highlighted select the "Split track" icon (4th icon along the top of Track List screen).
Image Could Not Be Found
Hope that works for you
466561
Follow Up By: Member - Wayne B (NSW) - Sunday, Oct 02, 2011 at 18:22
Thanks guys.
That worked ok. Little bit of experimentation and I managed to end up with a Trek with only ONE POINT, deleted everything else. LOL
Reloaded trek and started again. This time success. Worked a treat.
Thank you
Wayne B
740708
