jayco pengiun bent lift tubes
Submitted: Sunday, Oct 02, 2011 at 15:31
ThreadID: 89343 Views:4151 Replies:2 FollowUps:0
my 2000 model penguin broke are lift cable which I have replaced
my problem is the 3 of the lift tubes are bent , can the top part be replaced or do you need the hole tub assembly
any tips on fitting these parts would be appreciated
regards peter
Reply By: Member - Warrie (NSW) - Sunday, Oct 02, 2011 at 19:12
Hi Peter, had a bent tube on the Swan a few years back. Too tricky to repair so off to the dealer for a new one - the whole 3 tubes which slide inside each other. Propped up the corner with the crook tube with wood..... W
Warrie
AnswerID: 466600
Reply By: Nomadic Navara - Monday, Oct 03, 2011 at 00:22
Sounds like you could do with a copy of this handbook
Is this what you are after - Telescopic Tubular Camper Lifter, 3 Stage, No Wings - Genuine Jayco
AnswerID: 466625
