Leaky gas bottle
Submitted: Sunday, Oct 02, 2011 at 21:42
oz doc
Hi guys, just going through the last minute packing before departing tomorrow morning. Had the gas bottle filled today BUT- it seems to be leaking. The leak appears to be at
the neck of the bottle. The bottle is only 12 months old. So my question is- is it practicable to have it fixed and where would you go to get this done? In the meantime I will leave it outside to slowly discharge its load and take the spare away with us this week. Thanks, doc.
Reply By: blue one - Sunday, Oct 02, 2011 at 21:55
Get rid of it.
It would be a better result to have a new gas tight bottle.
I have a lot of respect / concerns for LPG which has led me to moving over to Shellite & Coleman
fuel lights & stoves.
Steve
466613
Follow Up By: Muddy.au - Sunday, Oct 02, 2011 at 22:19
Your not alone, Shellite/Coleman
fuel stove and 12v light for me, ditch the gas.
740724
Follow Up By: Bushranger1 - Monday, Oct 03, 2011 at 15:35
Yep. Good move.
Ditched LPG 20 years ago & went Coleman stove/lantern & 12v flouro too.
740767
Reply By: Hairy (WA) - Monday, Oct 03, 2011 at 04:52
Gday,
Spray or brush it with soapy
water and determine where the leak is and you might be able to nip it up a bit.
Dont leave the bottle around slowly leaking.....if you going to empty it......empty it........but keep an eye on it.
I wouldnt worry about getting it repaired.......just get snother one.
466629
Reply By: Member - MIKE.G - Monday, Oct 03, 2011 at 08:28
Hi OZ Doc. If you are talking about a 9kg bottle, I have found on a few occasions that when the bleed screw is screwed back in, there is ice in the thread and it does not completely close. It needs a further tighten after a short time when the ice has melted.
Mike
466636
Reply By: racinrob - Monday, Oct 03, 2011 at 08:35
Twice I have been in
camping areas/caravan parks where leaking LP gas bottles have ignited with terrible results, use the soapy
water as suggested and nip it up otherwise dump it.
rr
466637
Reply By: oz doc - Monday, Oct 03, 2011 at 10:09
Thanks all- the soapy
water test confirmed the leak. Left it outside o/night and it is half empty already. Will drop into BOC on our way out of town this am and see if they can dispose of it safely.Thanks again. doc.
466643
Reply By: kidsandall - Monday, Oct 03, 2011 at 16:43
Take it to a
servo and swap it for a swap and go. They test them before refilling. Cheaper than buying a new one.
Josh
466674
