Toyota 1HZ V 1HZTD Engine
Submitted: Monday, Oct 03, 2011 at 21:18
Member - Wayne B (NSW)
Hi all
I have a complete 1HZ engine spare and a 1HDT fitted in my vehicle.
I would like to know if the bottom end is the same as the 1HDT. Are there any changes or mods that have to be done to convert the 1HZ to a 1HDT bottom end.
I was thinking of rebuilding the 1HZ and then fitting the 1HDT head,
fuel pump etc to the rebuilt engine. This way I would not have my vehicle off the road during the rebuild.
Wayne B
Reply By: Member - Anthony W Adelaide - Monday, Oct 03, 2011 at 22:18
Hi Wayne,
I am pretty sure that the big end of the conrods are alot beefier in the turbo motor to cope with the extra power and would not be interchangeable. Crank and bearings may
well be different too.
Check out LCOOL.org (Land Cruiser Owners On Line), lots of info and like minded people on there. You have to join but its free and
well worth the effort IMHO
Cheers, Wooly
466728
Follow Up By: Member - Wayne B (NSW) - Monday, Oct 03, 2011 at 22:33
Thanks for replying. I have posted on LCOOL as
well just waiting for a reply
You could
well be right about the rods ect.
Wayne B
740825
Reply By: fisho64 - Monday, Oct 03, 2011 at 23:05
try the toyodiy website and look up the part numbers, that will tell you for certain.
466736
Reply By: Member - Joe n Mel n kids (FNQ - Monday, Oct 03, 2011 at 23:28
i know it is not easy to search LCOOL but i posted the same question some time ago...
The block is basically the same, it does not have the oil outlet for the turbo supply or the drain tapped in, you simply tee off the oil pressure swith for supply and drain into the sump ... one thread on LCOOL has some really good pics eh...
The crank is supposed to be exacly the same, but you need to change the rods and pistons, both at available on EBAY ......
The head from the HDT also has some
water plumbing and hoses ect to fit and change but very do-able.......
Cheers and good luck with it, i will be doing
mine in the next 6-12 months ...
Joe
466738
Follow Up By: Member - Wayne B (NSW) - Tuesday, Oct 04, 2011 at 16:23
Thanks for that
I have been looking at various 80 forums and Looks like it can be done with some modifications.
Thanks again
Wayne B
740876
Follow Up By: pop2jocem - Tuesday, Oct 04, 2011 at 22:59
Wayne
I was looking to do a similar mod to my 1HZ but I was lucky enough to find a low k 1HD-FT complete from a written off 1997 80 series.
While doing the research for a 1HZ to 1HD-T conversation I came to the conclusion that cost and off road time was, for me anyway not worth the hassle. The block and crank were no dramas but be careful of little items that could effect reliability such as oil spray nozzles under the piston skirts and changing the
fuel pump over to suit the injection pressures of the 1HD-T injectors and the aneroid to prevent overfueling at low boost pressures. I am not sure if the oil pump is the same seeing as how you would need extra oil volume.
Having said that yes it does appear do-able but it may be easier and more cost effective to get hold of a 1HD-T or if you can find one a 1HD-FT and do a standard re-build while having the use of what you have.
Good luck
Pop
740917
Follow Up By: Member - Wayne B (NSW) - Wednesday, Oct 05, 2011 at 20:15
Thanks Pop
Yes I agree. I think I will rebuild my 1HDT when it needs it and not worry about converting the 1HZ.
Its just I have the 1HZ sitting in the shed and I thought it could be a viable alternative and I could take my time building it up and then swap the engines over when I am ready.
Thanks for your input
Wayne B
740993
