Wednesday, Oct 05, 2011 at 09:53
hi stevo and macca 44
paper air cleaner elements can be cleaned several times
as an ex farmer i have cleaned many paper elements on my farm tractors sometimes daily in extreme dust conditions due to soil type
90 psi is safe we had 3 john
deer tractors and a jd header all with paper elements so i am speaking from a volume of experience on this subject and am happy to pass this on
but dont put the air nozzle right on the element keep it back about an inch/25mm clean from the inside but also remove outside dust with deflected air or with vacumm cleaner dont scrape the vax nozzle on the element flutes or you may damage them
i have also used the shed vacumm cleaner
an old vax with the same success
i currently have a 1997 after-market safari turbo'd bravo diesel mazda that i purchased new and have cleaned the paper element several times and its still in a1 condition and the engine is not starving for air or using extra
fuel
i have a 40w globe test light that i put inside it after cleaning to make sure there were no small perfurations in the paper if you see a small pin hole or any signs of thinning of the paper then ditch it and replace the element
truckline parts usually have the filters and have reasonable prices
cheers barry
740941
