Hayman Reece weight distribution bars 800 lb
Submitted: Thursday, Oct 06, 2011 at 18:33
ThreadID: 89407 Views:2928 Replies:3 FollowUps:3
Hi. All.
What is the best way to set up this system, including the location of the pull up brackets on the A frame, as I have just re shaped one of the pull up brackets by doing a tight U turn.
Reply By: Member - barry F (NSW) - Thursday, Oct 06, 2011 at 18:50
Hello H, Well when we purchased ours a few years ago Hayman Reese supplied a very clear & simple to follow set up procedure, so we had no problems.
Did you buy it new? If so, go back to your retailer & ask for some advise/instructions.
If the WDH came with a pre loved van & you do not have the above mentioned instructional leaflet then I would suggest you contact HR, maybe google them for contact info, & they will be more than happy to help you, as I think most reputable tow bar fitting places would be.
Good on you for having one anyway, they are a great safety device & in my opinion should be a lawful requirement for all vanners regardless of the size of van or tow vehicle.
Good luck & happy travelling.
AnswerID: 466942
Follow Up By: Member - " H " (VIC) - Friday, Oct 07, 2011 at 08:58
Thanks Barry and all for your comments, I'll try and contact H/Reece and get the instruction brochure if they have one,
Regards and travel safe, " H " Vic.
FollowupID: 741102
Reply By: Notso - Thursday, Oct 06, 2011 at 19:08
Detailed instructions here
Setting up HR WDH
AnswerID: 466946
Reply By: landseka - Thursday, Oct 06, 2011 at 19:22
One of the first instructions should be "Don't do tight U-turns with the hitch fitted!"
I always disconnect mine before entering a caravan park and don't re-connect until out in the street for just this reason.
Cheers Neil
AnswerID: 466947
Follow Up By: Member - barry F (NSW) - Thursday, Oct 06, 2011 at 20:53
Hi Neil,
I hear what you say but we do not have the problem you mentioned. It's a while back since I set ours up but seem to remember that this potential problem was addressed in the set up procedure & think it was related to leaving sufficient chain links?
It's a bit late for me to go check out our set up manual now, but we have never had to disconnect prior to parking our van & always hook up the WDH prior to pulling off the park site.
Maybe worth asking the question of HR or an authorised installer of the system to get rid of any concerns or problems you may have. Cheers
FollowupID: 741080
Follow Up By: snoopyone - Friday, Oct 07, 2011 at 09:17
Always leave at least 4 links and preferably 5 links free.
Why Because the bars move back and forward in turns and I have actually seen broken bars from not leaving enough and it has snapped.
HR also recommend you dont reverse over gutters etc when they are fitted.
I only did it once Never again nearly had serious problems when the bars dug into the face of the gutter.
If you need to adjust them to get the required number of links you just remove the top bolt and turn the cam around to push the towball back or forward depending on what you want.
It does NOT have to be vertical.
The instructions tell you how to get the hitch at the correct height for the van to be level.
FollowupID: 741105
