Will a 2 kva Honda Generator run a 3.0 Heron ac.
Submitted: Saturday, Oct 08, 2011 at 15:34
Nickywoop
I am about to buy a generator to use on my caravan when we go and stay at our scrub block. Will a Honda 2kVA EU20i run a 3.0 Heron air conditioner with no over heating problems in the summer.
Or will I be better going to a Yamaha 2.4 kVA inverter generator, which is about 11 kg. heavier. The weight is no problem as we would not be taking it on trips.
Regards Nick
Reply By: stevo - Saturday, Oct 08, 2011 at 15:56
Hi Nickywoop --------- What does the "3.0" mean on your A/C --------- If it means 3000 watts then your 2kva generator puts out 2000watts and therefore won't be big enough ---------- You need to determine how many watts your A/c is ----- It should be marked on a plate usually with the serial no. etc.
467111
Follow Up By: Nickywoop - Saturday, Oct 08, 2011 at 16:40
Thanks Stevo,
I have a squizz when I am out at the block next.
May be another of the EO group maybe able to let us know.
Regards Nick
741202
Follow Up By: paulnsw - Saturday, Oct 08, 2011 at 20:41
"your 2kva generator puts out 2000watts" try 1,600W
741234
Reply By: Duncanm - Saturday, Oct 08, 2011 at 17:06
On the net this link
link to heron 3.0
it takes you to the spec below which looks like its 3200 watts so your Honda 2 wont do it by the look of things.
Looks like you will need quite a large generator.
Duncan
Heron Q Split System Air Conditioner
Electrical rating: 240V,50hz
Nominal cooling capacity: 3.2kw
Nominal heating capacity: 3.2kw
Maximum rated current, cooling: 6.5A
Maximum rated current, heating: 6.5A
Locked rotor current: 20A
Inside Air Delivery, Maximum: 138l/s
Installed Weight: 38kg
Condensor Height: 770mm
Condensor Width: 455mm
condensor Depth: 295mm
Air Handler Height: 240mm
Air Handler Width: 380mm
Air Handler Depth: 250mm
Minimum cupboard dimensions required 490mm Wide x 290mm High x 310mm Deep
467117
Reply By: Member -Dodger - Saturday, Oct 08, 2011 at 17:21
Heating for the Heron 3.0 = 1500 Watts
Cooling : : : 3.0 =1600 Watts.
Yes a Honda EU20i will run the air con.
I tried this Generator on
mine and it ran it OK. The temp at the time was however only 30% C. The generator was my mates and it was working very hard so that is why I purchased a 2.6kva Genny.
Note that the Honda EU20i is rated to a continuous rating of 1600 Watts.
My 2.6kva is rated at 2000Watts continuous.
Hope this helps.
467119
Follow Up By: Nickywoop - Saturday, Oct 08, 2011 at 17:26
Thanks for that Dodg,
Well looking at the figures you have up there, the Yamaha 2.4 should handle it without being worked to the max all the time.
Has anybody tried a Yammy 2.4 on a Heron 3 ?
Nick
741208
Follow Up By: Member -Dodger - Saturday, Oct 08, 2011 at 17:27
I looked at the above link and it is different to what is in the heron handbook supplied. never the less as stated above my 2.6kva unit does run
mine.
741209
Follow Up By: On Patrol & TONI - Saturday, Oct 08, 2011 at 18:00
Nickywoop
I run my Heron 3
well from the EU20i & have done for 18 months in searing heat as
well as snow & ice.
Cheers Colin.
741213
Reply By: shanegu6 - Saturday, Oct 08, 2011 at 18:17
Hi Nick, I have owned both the yamaha and the Honda. Both generators will run the heron 3 with no problems but everything else needs to be turned off at the power point, including your inbuilt battery charger. I had the yamaha for 5 years before the inverter in it died. Wasn't worth fixing for $1200 or more so I bought the Honda and hoping for a longer life span out of this.
467125
Follow Up By: Nickywoop - Saturday, Oct 08, 2011 at 20:10
Hi Shanegu6,
What size Yammy did the inverter die in.
Regards Nick
741226
Follow Up By: shanegu6 - Saturday, Oct 08, 2011 at 20:33
The 2.4kva model. The big cumbersome thing. After having both gennies the Honda is so much more user friendly.
741231
Follow Up By: paulnsw - Saturday, Oct 08, 2011 at 20:45
The Yamaha EF2400iS is the superior option if you can afford the extra weight. The Yamaha is a heavy duty more industrial type unit, quieter and uses less fuel.
Main issue with the Honda EU20i they WILL NOT work over 40C at high loads and the hand book is very specific about stating that fact. If you want reliable cooling in summer heat, the Yamaha EF2400iS is the only choice.
741237
Follow Up By: Nickywoop - Saturday, Oct 08, 2011 at 21:12
Thanks Paul,
Looks like the Yamaha is gunna get the chocolates, unless somebody has had experience wit some other good make of genny.
741243
Reply By: paulnsw - Saturday, Oct 08, 2011 at 20:45
467133
Reply By: Isuzumu - Saturday, Oct 08, 2011 at 21:19
Toss the aircondition buy a 240 volt fan, uses about 40 watts, run it off an inverter, forgot to add open the windows.
467136
Follow Up By: kevmac....(WA) - Monday, Oct 10, 2011 at 17:21
def best and cheapest way.............
741379
Reply By: Member - Andrew L1 (SA) - Sunday, Oct 09, 2011 at 17:09
I have a Honda EU20i and it runs my Heron Q in a Coromal 541 Poptop. It will not run it when the honda ECO throttle is on.
Andrew
467189
