Jackaroo 3.1 TD Manual tail shaft damper
Submitted: Thursday, Oct 13, 2011 at 07:51
Member - Todd S (QLD)
Hi Guys
Just bought a 97 3.1TD and am working through some repairs it needs. One of the things I have noticed is the shaft damper just behind the gearbox a has a lot of play in it and I think is actually introducing more vibration (at low RPM) than it is removing.
Can it just be removed because it is not fitted to all models and Holden want nearly $600 for a replacement!!?
I have read on many forums for different makes that it is not essential and as I said I think it will be doing more harm than good the way it is.
Reply By: Madfisher - Thursday, Oct 13, 2011 at 19:14
Hi Todd,
mate to get more specific info you may be better having a look at the jack
forum at australia 4wd .
Cheers Pete
467542
Reply By: Isuzumu - Thursday, Oct 13, 2011 at 19:23
It is the same set up as on my Isuzu MU (built in the same factory) and has been like it since I brought it 10 years ago, will have nothing to with vibration. Really do not know why it is there. Also check this site www.clubisuzu.com, but the Jackaroo
forum is probably the best.
467543
Reply By: Todd S - Friday, Nov 11, 2011 at 10:14
General consensus is that it can go. Out with the angle grinder I think.
469735
