Fittng a water tank to the cruiser
Submitted: Sunday, Oct 16, 2011 at 21:24
Trev6
Hi All, I am looking for ideas from anyone who has fitted a
water tank to an 80 series under the floor on the left hand side near the chassis rail, what did you use and how was it mounted?.
I am thinking along the lines of some 150m pvc pipe that will hold around 15L . It will then be hooked to a pump and twine heat exch. to be used for hot
water while on the road at meal times
Any other ideas of a suitable
tank and fitting would be a big help.
Thanks,Trevor
Reply By: Member - Phil B (WA) - Sunday, Oct 16, 2011 at 21:41
Reply By: Member - Andrew L (QLD) - Sunday, Oct 16, 2011 at 22:18
15 litres in some PVC pipe, and thru a Twine heat exchange for some warm
water for dinner..?
Whats wrong with gasing up some boiling hot
water out of a 20 litre jerry for cooking the veges and washing the dishes..?
If your serious about carrying
water, do some more googling, 15 litres is enough to
cook, wash up and have a shower..1 night.
467804
Reply By: rumpig - Sunday, Oct 16, 2011 at 22:38
Reply By: pepper2 - Monday, Oct 17, 2011 at 15:57
In my gu patrol there is enough space between the outer metal skin and the inner lining over the rear passenger wheelarch to install a 20 litre
water bladder made by a company called floatpac.Totally secure never had a puncture or contamination.Totally hidden takes up no storage space,they make them for many vehicles.
467846
Reply By: Trev6 - Monday, Oct 17, 2011 at 17:17
Thanks for the replies so far.
Most of you have questioned the size of the
tank (which I would like to go bigger if I can), I only want something big enough for the kids to wash their hands under befour getting back in the car or maybe rinse a few dishes and then top it up again that night, by running it through the twine into a bucket it would make it a bit more plesant in winter and that way it would avoid carrying gas around, also handy on total fire ban days.
I we are staying for a few days in the one spot we would then have our trailer with us which has it's own bigger
tank.
467854
Reply By: Member Boroma 604 - Monday, Oct 17, 2011 at 18:32
Reply By: louie the fly - Monday, Oct 17, 2011 at 19:09
Not sure about how to mount the pipe under a LC80, but you'll defs need to make a decent shield to protect the pipe and the fittings, otherwise it'll get busted in no time from stones thrown up underneath. You might be able to run the shield from the chassis rail to under the sill panel, or to your running board brackets. You can get brackets for the pipe (Bunnings, et al) but they're not very strong. They're OK for securing a pipe to a wall but that's about it. If I was gonna do it I'd make it out of stainless steel tube with end caps welded on (the ends). Then you can also integrate the brackets into the
tank, and you could even weld on some standoffs to attach your shield.
I had a PVC pipe across the front of my old camper trailer to store annexe poles. 1st detour off the bitumen and it was broken in seconds. So basically, it turned out to be a WOFTAM.
Good luck
Louie
467866
