Gas fridge and strong winds?
Submitted: Tuesday, Oct 18, 2011 at 20:08
coral and jussy
Hi all, can't fault our fridge when working on gas in terms of its coldness and reliability unless we have a direct and strong wind which continually blows out
the pilot light. Is this an issue for others? We are on
the loop around oz and close to
Perth and can pretty much use 240 volt til then. Should we book it into Dometic or are there other creative solutions out there that we can try? Thanks in advance for your help.
Col and Justin
Reply By: Rangiephil - Tuesday, Oct 18, 2011 at 20:12
Shield the flame from the wind with eg a chopping board and turn the fridge so that the flame is not directly in the wind.
Regards Philip A
468005
Follow Up By: coral and jussy - Tuesday, Oct 18, 2011 at 20:17
Thanks for your speedy reply! We have tried a number of alternatives to shield the flame and when the site allows we have turned the van so as to avoid it but this is not always possible. Very windy in
Cape Range National Park but other vans seemed to cope ok last week. Probably looking for a more long term solution.
742142
Follow Up By: Bob Y. - Qld - Tuesday, Oct 18, 2011 at 21:16
We lived in a van for 6 years, and when SE winds blew the fridge out regularly, we'd put a cover over the external fridge vent. Just used enough duct tape, and bit of old bag, to block the worst of the gusts.
Some will say "not safe", but if it's a bit loose, then there's some ventilation anyway. If the wind is that strong, then it's going to blow most of the fridge into the van anyway.
We didn't shift the van around at all, as liked to keep the nearside(and annexe) to the north.
Bob.
742165
Follow Up By: Bob Y. - Qld - Tuesday, Oct 18, 2011 at 21:18
That would be: "blow most of the fridge heat.....etc"
742167
Follow Up By: coral and jussy - Wednesday, Oct 19, 2011 at 12:41
Thanks for the advice and we did try that but gusts still seemed to get through. I guess we were curious that others in the campground were all ok and is it that there is an issue which can be fixed by having the fridge serviced?
742231
Reply By: timothy - Tuesday, Oct 18, 2011 at 21:05
Ours used to do the same thing, to fix it I put insulation around the fridge so that the wind didn't blow through the fridge cabinet and into the van when it was blowing towards the vent and also blocked about 2" of the vent on the chimney side to about half way up the fridge. The insulation helps keep things cool as
well as blocking air flow, to combat heat I installed two small fans behind the fridge blowing out of the vent with a temperature operated relay.
My van is the older style with the vent that runs the height of the fridge at the back, the newer vans only have small vents at the top and bottom so this fix might not be possible
468011
Follow Up By: coral and jussy - Wednesday, Oct 19, 2011 at 12:42
Ours is the newer version you described but thanks for the suggestion!
742232
Reply By: Roughasguts - Wednesday, Oct 19, 2011 at 14:05
Bit of shade cloth over the vent might be the go!
Cheers.
468056
