Thursday, Oct 20, 2011 at 09:07
The 200 series is overall not to bad for a 4 wheel drive.... except for!
1) Drinks
fuel at a astounding rate.... some owners get really good
fuel economy and others don't, after doing a bit of research it appears 3lt Nissan Patrol owners have the same issue.... some good some bad.
2) Slight torque steer under hard acceleration.
3) Trans will not hold the vehicle on a slight incline with out rolling back.
4) Chimes, chimes and chimes..... everything has a chime.
5) The factory radio has a user set function that turns the screen off after 20 seconds.... the down side is you still have to push a button every time after starting to activate this function.... there is a prompt that comes up on the screen saying" Display off/on after 20 sec".
6) Hate the trans.... why do I have to be pulling 3000 rpm up a slight
hill in 3 gear at 100Kph.... the massive power and torque is let down by the trans down shifting to early... the trans is set this way in the name of meeting emission targets.
7) The GXL is over priced and the Sahara is over priced, get a VX.
8) Requires a GVM upgrade if touring with any more then 3 people.... LOL
9) Keyless engine start is good but becomes annoying when switching between acc-on-start-off when wanting to use the elec windows or windscreen wipers ( like at the footy sitting in your car).
10) Head lights don't turn off with the ignition unless you open the door.... if you pull up somewhere turn the vehicle off and turn it to accessories to listen to the radio with out getting out the vehicle the lights stay on.
11) Struggles to climb big hills with heavy loads when taking off... trans issue.
12) Have to stop and place the trans in neutral before selecting Hi or Low range.
Apart from those thing that an average drive will not notice they are a very capable hiway and off road tourer that eats up the kilometres with ease, we have not had any of the so called "common" problems that the internet seems to discover.... there are some known issues on some Landcruisers but few and far between.
Ours is a 2011 VX with all the after market junk including a Lovell GVM upgrade and
suspension lift.
Most of the things I have listed above are our personal gripes only because we upgrade our vehicles regularly and have other late model hi end vehicles that we are comparing the Land cruiser to... is the Land Cruiser over priced NO.... believe me after working on a friends fleet of Patrols in our workshop you can see where the other $40,000 is and even he is starting to bit the bullet and look at 200 series.
468112
Follow Up By: Member - Boobook - Thursday, Oct 20, 2011 at 15:04
olcoolone
mine had really bad torque steer. I had a wheel alignment and it went away completely.
Also you can have the dealer turn off the chimes for the
seat belts and for the rest of the dings, you can put tape over the bloody thing to shut it up. I guess a lot of the rest of your issues are subjective, especially the relative value. After having the center consol fridge I would never get anything else. It's brilliant.
742371
Follow Up By: Kris and Kev - Friday, Oct 21, 2011 at 08:21
Olcoolone, maybe you really need to get a different vehicle? Especially if your 200 goes into 3rd gear when doing 100 up a slight
hill. Is that when you are towing a large caravan? When we are not towing our vehicle stays in 6th gear up most slight hills, or it just drops into 5th? I don’t mind the chimes; it does remind me to put the
seat belt on. I don’t mind the head lights feature, beats a flat battery.
I think it would be very difficult to find a ‘perfect’ vehicle. And unfortunately all modern vehicles have lots of electronics and gizmos. We just cannot get away from it. I think the real problem with new four wheel drives is that they are marketed for the 95% of buyers who never take them off road and live in or close to major cities!
We have taken our 200 into all sorts of terrain and love it, 100,000 on the clock and lots more to come. PS, it is only a GXL.
742418
