2 inch lift
Submitted: Wednesday, Oct 19, 2011 at 17:59
Member Andys Adventures
Just had the Triton lifted 2 inches, It was done by after market 4wd
shop. After taking it for a test drive the ATSC started to come on, and after awhile it was on nearly all the time. This affected the motor management, and at one stage would only do 900 rpm. After turning it off and restarting it it went back to normal but with restricted power. After taking it to a dealer and hooked up his computer, was told that you have to have the ATSC readjusted. After readjusting everything is fine. So just a heads up on new cars with ATSC, if you do a 2inch lift go back to the dealer and have it adjusted.
Reply By: Member - MUZBRY(Vic) - Wednesday, Oct 19, 2011 at 20:15
Gday
Don't want to sound ignorant , but what is an ATSC. ?
468087
Follow Up By: Outback Gazz - Wednesday, Oct 19, 2011 at 21:04
Hey Muzbry
After all your knowledge on spring rolls and womens buttons, I thought you would at least know this one !!
Gazz
742299
Follow Up By: kidsandall - Wednesday, Oct 19, 2011 at 21:11
I'm with you Muzbury, and I assume outback Gazz doesn't know either lol.
Josh
742302
Follow Up By: Member - MUZBRY(Vic) - Wednesday, Oct 19, 2011 at 21:18
Gday
So the $60 .00 question is. What is it?
742304
Follow Up By: Member - MUZBRY(Vic) - Wednesday, Oct 19, 2011 at 21:50
Gday
I have looked it up and I think there might be a typo could be ASC " active steering control ". I down loaded the Triton information from Mitsubishi.
I have been wrong before and admit to my fallibility. I am not a woman there for I am wrong all the time .
742311
Follow Up By: cookie1 - Wednesday, Oct 19, 2011 at 22:25
electronically controlled four-wheel drive with an Active Skid and Traction Control (ASTC) system
742313
Follow Up By: Member - MUZBRY(Vic) - Thursday, Oct 20, 2011 at 05:54
Good morning
Thanks cookie . I looked up the Mitsubishi info and did not see that bunch of initials.
742334
Follow Up By: Member Andys Adventures - Thursday, Oct 20, 2011 at 08:23
You win the 60,000 $ question cookie 1. That is exactly what it is, sorry i didn't put it in in the first place. I was told by Mitsubishi that if you even changing the shocks you have to have it done.
742339
Follow Up By: Member - MUZBRY(Vic) - Thursday, Oct 20, 2011 at 09:05
Gday
Thanks Andy, that makes it all a lot clearer.
It's only $60.00 not $60000.00 .
742342
Follow Up By: vk1dx - Thursday, Oct 20, 2011 at 09:22
I'll bite then.
What is Active Steering Control?
Is it something you turn on when you do not have a designated driver?
742345
Follow Up By: Member - MUZBRY(Vic) - Thursday, Oct 20, 2011 at 11:51
GdayPhil
I have no idea, but it sounded good ....active steering on my unit is when i am awake and steering...
742357
Follow Up By: cookie1 - Thursday, Oct 20, 2011 at 19:24
Thanks Muzbry, I'll wait by the mailbox for your cheque for $60.00 and again for the cheque for $59,940.00 from Andy's Adventures. I can then afford to go on a nice long holiday in my non ATSC vehicle - Anti Traction & Skid Control 4WD.
All in good humour
Colin
742387
Follow Up By: Member Andys Adventures - Thursday, Oct 20, 2011 at 19:24
It helps with cornering on wet and dirt roads, and when you have too much body roll. If one wheel loses traction then the brake is applied until traction is gained again. It will not operate in 4wd. New cars today are electronic nightmares.
742388
Follow Up By: vk1dx - Thursday, Oct 20, 2011 at 19:58
Next we will get a remote controller with new cars so that you can sit in the back seats with the DVD screen. Nah!! Takes all the fun out of driving.
Ours would be off most of the time we are in the bush and when on good roads it would be a waste of money.
742390
Follow Up By: Member - MUZBRY(Vic) - Thursday, Oct 20, 2011 at 20:46
Gday Cookie
Ill fax the $60 .00 cheque to you when I buy a fax .
742399
Reply By: Robin Miller - Thursday, Oct 20, 2011 at 19:49
Good to Know !
Its getting worse as
well Andy with many new cars having Electronic Stability Control also (ESC - thought I'd save Muz from having to figure this one out).
This is adding another level of complexity to even changing wheel sizes , we have recently gotten away with a 40mm lift on an 2008 R51 pathfinder , so they don't yet need it.
The ability to do these things without hassle was one of many little less obvious reasons I recently went with a 2010 4800 GU patrol.
468156
Follow Up By: Member - MUZBRY(Vic) - Thursday, Oct 20, 2011 at 20:29
Gday Robin
Mine has all of the above and work in mysterious ways . MNASTC (manual non active traction control ) and MSC (manual stability control) .
I hope it is now clear to all.
742396
