LPG AUTO GAS UNIT FREEZING.
Submitted: Saturday, Oct 22, 2011 at 01:01
ThreadID: 89686 Views:8094 Replies:6 FollowUps:2
hi guys,
my 2f 60 series landcruser is on gas and the gas unit is freezing up every now and then. Can anyone tell me why and how to fix it?
cheers REEVO.
Reply By: Member - Stuart P (WA) - Saturday, Oct 22, 2011 at 01:13
in sufficient water flow thru the gas regulator/mixer
AnswerID: 468283
Follow Up By: mikehzz - Saturday, Oct 22, 2011 at 06:31
Yep, check you have enough coolant in the radiator and that there are no blockages. It uses the hot water from the radiator to stop itself freezing.
FollowupID: 742523
Reply By: Bushranger1 - Saturday, Oct 22, 2011 at 08:01
G'day Reevo,
I addition to already mentioned items if you have changed the coolant recently an air lock in the coolant pipes to the gas exchanger could do it.
Check that they feel warm with the engine up to normal temp.
Also check that engine is not running too cool due to thermostat stuck open.
Stu
AnswerID: 468288
Reply By: blue one - Saturday, Oct 22, 2011 at 08:51
I had a similar problem in a company car and it turned out that the orifice limiting gas flow was too small.
AnswerID: 468298
Reply By: dazren - Saturday, Oct 22, 2011 at 10:38
Had same problem with ford Egas ute, turned out to be the Thermostat ??
AnswerID: 468316
Follow Up By: Road Warrior - Monday, Oct 24, 2011 at 15:49
Yeah I have always drilled the thermostat base whenever replacing one in an LPG vehicle
FollowupID: 742728
Reply By: Member - Colin Y (VIC) - Tuesday, Oct 25, 2011 at 07:47
REEVO:
Is the water flow through the converter in "series" or in "parallel" with the cabin heater? "Y" fittings should be used in the plumbing of the hoses, so that water circulates regardless of the thermostat or the heater control valve. Even "cold" water passing through the converter is fine, as long as it is above minus 40 degrees!
If the vehicle ran OK before, there would never be a need of increase the size of any valve orifice in the converter.
Is the power and fuel economy OK? What brand of LPG carburation do you have?
Does the LPG lock-off have ice forming on it? If so, the filter needs to be replaced, as it will be blocked too much.
Colin
AnswerID: 468491
Reply By: Bernie C - Tuesday, Oct 25, 2011 at 10:45
I had to change out the complete heat exchange unit on my work ute as it would ice up.
Started as every now and then but in the end would only get about 20Km and it die.
AnswerID: 468503
