Sunday, Oct 23, 2011 at 13:40
I have often wondered about that 10% theory as
My first introduction to towing dates back to the time I commenced working as a 15 year old apprentice mechanic in 1961. I would occasionally hear the boss discussing tow ball weights with customers. The figure that came up all the time was around 70 lbs. That would be about 32 kgs for a 1000 kg van or boat trailer. That seems very light but I can't remember a customer ever having a towing accident.
When I was old enough to get a driver's licence, my mates and I went straight into towing old 1930s cars on rented four wheel trailers. We would push the
old car forward on the trailer until the rear of the tow car went down "a little bit" then tie it on and away we would go. We never had a problem.
I tried the same practice when my wife and travelled for a year with a small van after we married in '74 and once again there were no problems.
I have not towed anything for many years but if I did I would be asking a lot of questions about caravan suspensions. I can't help but think they may be contributing to swaying problems. To me they look so primitive. You still see plenty of solid axles with springs heavy enough to hold up a train but with no shocks. Look up what Colyn Rivers thinks of that idea. At least the
wheels stay upright on corners with that system though.
The independents usually have a heavy A arm pivoting off four bushes mounted on a straight chassis crossmember. With this design the
wheels can only go straight up and down so as the van leans the tyres also lean reducing tread contact with the road. Car manufactures often use a similar design but they don't place the pivot points in a straight line across the chassis. The inner points are usually positioned a little further to the rear than the outer ones. This means the wheel changes camber as it moves just like the front
wheels do. The idea is to keep the wheel on the outside of a corner as vertical as possible to maintain full tread contact.
The old VW used this type of trailing axle design on their cross torsion bar front
suspension. It was never noted for its good handling qualities although I did read somewhere once that there was some degree of bending designed into the trailer arms for camber compensation. I doubt if that idea has been built into current vans.
The other issue with van suspensions is the lack of sway bars. If vans can sway then why don't their manufacturers use car style sway bars to transfer weight from the outside
wheels in a corner over to the other side in order to keep the van more level? Is there a technical reason for not doing this or is it just economics or in the research and development too hard basket?
To date I have not looked at any imported European vans. Their recommended tow ball weights seem to be a lot lower that locally manufactured vans. I have also read about them being towed at
well above 200 kph behind Porsches and the like. That might be only on roads like the autobahns but what happens if it runs into a sudden strong cross wind? One would expect the suspensions to be designed to cope with that so are they different to local vans?
468393
Follow Up By: vk1dx - Sunday, Oct 23, 2011 at 23:10
Thats about the weight we used on the tow bar. Around 70Lbs. I am not a mechanic but I see what you mean about the trailing arms. Didn't the Mini have something along the same lines. I never got much about 80Mph with the Chesney on the back but at that speed it sat there like a rock.
I don't tow anymore. Having a van on the back is too restrictive. Even today we were in the Monga NP near
Braidwood and there is no way that you could even get a good 4WD van/trailer around the old parts of
Boundary Track. We just went for a picnic where we had not been before. The hills around here hide some great spots.
But I digress. It doesn't worry me apart from the terribly annoying
bright lights coming the other way. You know the ones. They are on the car that has a van on the back and th driver is too stingy or lazy to adjust either the balance of the car or get the lights fixed. Even in the daytime the glare can be bad. And we all know that is illegal - Don't we!
So after a good day in the hills I am off to bed.
Thanks for the post and memories.
742691
