Alko suspension
Submitted: Monday, Oct 24, 2011 at 23:59
walwffoeg
I have an Aliner which has Alko
suspension.
The first night from brand new I wiped off the rubber feet from the rear stability jacks and that was inside a caravan
park!
It's way too low and I am wondering if it's possible to adjust the height on these Alko suspensions?
Geoff
Reply By: Member - Vince M (NSW) - Tuesday, Oct 25, 2011 at 07:55
If its the std (all in One axle,
suspension) alko the only way I no is to block it at the mounting points, other than that you can order a new axle kit with the height required, I have have several made for boat trailers & if alko tell you six weeks it is at least ten
good luck
468492
Follow Up By: walwffoeg - Thursday, Oct 27, 2011 at 08:09
If I block it at the mounting points, the shock absorbers would then be too short. (I am going from memory here) I could maybe fit new longer ones, or just leave them off. My previous Avan didnt have shock absorbers.
742928
Reply By: ozjohn0 - Tuesday, Oct 25, 2011 at 14:12
From memory the Aliner has a overlay beam axle.
Your alternatives are to have a straight axle fitted or a
suspension riser welded to the chassis.
If going for the straight axle option oreder the replacement axle with a Camber Bend otherwise it'll be supplied dead straight which will result in increased tyre wear. This option wil raise the van around 45 - 48mm. For a short Aliner you'd certainly notice the difference.
A standard Chassis riser is 50mm.
Higher risers can be fitted as can a Spring over axle converion which will raise the van around 100mm, but that presents problems with the coupling then being illegally high.
Speak with your local van service man for the option that best suits you, but I've found over the years that a rise of 50mm (2") suites most vans very
well especially the shorter ones like an Aliner.
Cheers, ozjohn.
468512
Follow Up By: walwffoeg - Tuesday, Oct 25, 2011 at 14:21
Thanks guys.Sounds like the riser is the way to go....(or a new van if my super ever picks up!)
742802
Follow Up By: mynance - Friday, Oct 28, 2011 at 00:05
My Avan has a Alko independent rubber
suspension also, I am looking at ways of raising it to take the same 17"
wheels as the tug.
Myles
743012
Follow Up By: walwffoeg - Friday, Oct 28, 2011 at 10:09
How much higher would you need to go to fit the 17s? The
wheels themselves should raise it an inch or 2 compared with the std 185r14s.
My tug also has 17 mags, not easy to source them 2nd hand, although i did manage to get one from mr mags.
743024
Follow Up By: mynance - Friday, Oct 28, 2011 at 10:33
I have a NT Pajero and often see people who have fitted different mags wanting to sell the OEM
wheels.
I will have to find out if the axle size and bearing to take the extra leverage.
Myles
743030
