Wednesday, Oct 26, 2011 at 17:09
Charlie has made some good points
But First lets get the details clear
[I ] The Fridge is A 3way 240v ,gas or 12v???
If yes it should not be used on 12v exceptvia the TUG battery with engine running AND some form of prevention of over discharging the TUG starter battery
[ignition controlled real , Fridge Sitch motion sensing devise]
[2] If a 3way run on gas or 240v if mains power is available
[3 A 25 amp charger should more than cope with the fridge load current, but no point in using it to operate the fridge, USE MAINS power 240v option
[4] the charger should not give any loss of voltage unless [a] you have it conected the wrong polarities [b] OR it is faulty
[5]
IF the fridge in question is a compressor fridge 12v /240v [no gas]
How are you connecting it to the battery & charger ???
[6 ] The charger must be connected direct to the batteries with good clean tight connections AT ALL TIMES
[7]Connecting a compressor fridge direct to a charger IS A NO, NO, NO!!
742901
