Ute Advice
Submitted: Tuesday, Oct 25, 2011 at 11:14
ThreadID: 89729 Views:2318 Replies:3 FollowUps:3
Hi All,
Looking at utes as my 2 suzzies are just not big enough, engines are to small to tow a trailer and are getting old for longer trips.
I want to try and keep the weight down to a minimum as I would like to flat tow it behind a bus. (original reason for the suzzies).
I have been looking at MITSUBISHI TRITON CLUB CAB, does anyone have any experience (good or bad) with these?
Would there be any others you think would perform much better for O/R touring?
Never owned a ute before, so thanks for any thoughts
Rgds
Ian
Reply By: D&G - Tuesday, Oct 25, 2011 at 11:27
have a look at the Isuzo D-max - just ordered one - good value - Good luck
AnswerID: 468504
Follow Up By: Member - Noldi (WA) - Tuesday, Oct 25, 2011 at 11:31
Thanks D&G will have a look, but suspect they may be out of my price range
Looking around 15k plus or minus a few
FollowupID: 742790
Reply By: Madfisher - Tuesday, Oct 25, 2011 at 21:20
If you can find a Rodeo with the 2.8 td in it go for it. Theses motors have been known to do up to 700000ks, but are becoming sought after. This motor was superceded about 2003 for memory and good one4s sell for about $10000 to $12000.
Cheers Pete
AnswerID: 468545
Follow Up By: Member - Noldi (WA) - Wednesday, Nov 02, 2011 at 10:02
Hi Pete,
Sorry for the delay, been interstate for a week. Yep, from what I've seen the holden and toyota hold there prices well. Had 2 Jackaroo previously, happy with both
Thanks for the input, will check them out
Rgds
FollowupID: 743383
Reply By: Member - nick b - Tuesday, Oct 25, 2011 at 23:17
Hi Noldi ; If you can get a triton ml 3.2 TDI they go well &" just luv that car" but dont come in club cab but next model does .
The model before the ml is a good ute I had one for a few year no problems but no power house & does come in club cab as you might know !!
It wont matter that much what make you get more the deal you can get ,test drive as many as you can . good luck
cheers nick
AnswerID: 468568
Follow Up By: Member - Noldi (WA) - Wednesday, Nov 02, 2011 at 10:08
Thanks Nick,
Noticed you get a newer/less km in the Triton compared to the Holdens/Toyota.
Son had a 2wd triton that didn't miss a beat for the 3 years he owned it. I suspect your right it will come down to the deal
Rgds
FollowupID: 743384
