new thermarest self inflating mat not inflating?
Submitted: Thursday, Oct 27, 2011 at 09:33
ThreadID: 89764 Views:12269 Replies:7 FollowUps:19
hi all,
i went with advice from this forum to purchase a self inflating mat for a motorbike ride .......
only problem is i have now had delivered 2 of the same mats from the same supplier but both wont inflate properly!
the first one inflated only about 1/3. and surprisingly down the opposite side of the mat to where the valve was.
the replacement i was sent last Saturday has only inflated about 1/3 of the way but at the very top of the mat!
the mat i purchased was a new thermarest trail self inflating mat.
the supplier has told me to put it in the sun, it has been for 3 days now of 30+ degrees... the supplier said roll & re roll, done that & its still not getting any better...
has anyone got any suggestions for me to assist in inflating or what i should do?
I'm feeling i need to send it back & ask for my money back?
any help would be appreciated.
cheers,
Andrew.
Reply By: Member - jlAU (SA) - Thursday, Oct 27, 2011 at 10:24
Hello Andrew
how much do you expect it to inflate? 12mm-15mm wouldnt expect anymore than that.
john l
AnswerID: 468627
Follow Up By: Ozhumvee - Thursday, Oct 27, 2011 at 11:14
When they have been stored rolled up they can take a while to re inflate.
The time you have allowed plus the warmth in the sun should have done the job though.
Maybe they are old stock that has been stored for a long period tightly rolled?
They should always be stored inflated with the valve open, never leave them in the sun with the valve closed!
I keep ours on an old door hung horizontally from the garage ceiling.
FollowupID: 742935
Follow Up By: asmithy - Thursday, Oct 27, 2011 at 15:59
JlAU,
is a one inch mat and the top part is at near 20mm, so not far off at all & happy with that but the rest is flat & wrinkly! no inflation what so ever...
thanks ozhumvee for you help.....
andrew
FollowupID: 742951
Reply By: Rob! - Thursday, Oct 27, 2011 at 11:15
If one end of the mat is inflating and the other one isn't, it sounds like there is something very wrong with the mat. It's not something I've ever heard of happening to a thermarest. . Where did you buy it from?
R.
AnswerID: 468632
Follow Up By: asmithy - Thursday, Oct 27, 2011 at 16:01
online mega camping store, gosford nsw.
two 'duds' in a row is what im concerned about rob!
FollowupID: 742952
Reply By: Member - Oldbaz. NSW. - Thursday, Oct 27, 2011 at 11:16
Frustrating stuff..I would...1..send it back & ask for a replacement..but have them
test it first...or..2..if they wont oblige..ask for a refund.......oldbaz.
AnswerID: 468633
Follow Up By: asmithy - Thursday, Oct 27, 2011 at 16:03
im giving it another day in the sun to see if it improves before sending it back AGAIN......
Thanks Oldbaz. NSW.
FollowupID: 742953
Reply By: The Explorer - Thursday, Oct 27, 2011 at 11:20
With the mat I have (Metzler) it only "inflates" a certain degree. It is then necessary to blow air in using your mouth to achieve the desired firmness. This normally is only a breath or two. Maybe after time the mat will stretch/loosen a bit and self inflate a bit more but you will probably still need to add some air. Maybe blowing air into the mat and leaving for a while will even up the self inflation properties?
If there is actually something wrong with your mat maybe it is old and the inside foam has deteriorated? Bit hard to say if there is in fact something wrong or if what you are seeing is normal.
I always store the mat unrolled with the valve open (when not out camping).
AnswerID: 468634
Follow Up By: Mick O - Thursday, Oct 27, 2011 at 12:53
I concur with Greg. I have an X-large Thermarest that is now 14 years old and when not in use has been stored (wrongly) in rolled condition. The mat inflates to a certain point but I then add a bit of extra air by mouth until satisfied it's at the right height (about 5cm). The internal foam soon resumes its normal properties and the mattress still provides a comfy nights sleep.
Cheers Mick
FollowupID: 742937
Follow Up By: olcoolone - Thursday, Oct 27, 2011 at 14:27
Agree with Greg and Mick.... we use Thermarest in our swags and let them inflate for about 1/2 an hour before closing the vents plus we give 3 to 4 extra puffs.
FollowupID: 742940
Follow Up By: Bill BD - Thursday, Oct 27, 2011 at 14:56
My thermarest has always been stored properly and I still need to puff it up to get my hip off the ground BUT you shouldn't have to with a new one. It is not recommended as the moisture from your breath can cause mildew and I suspect puffing it up might void the warranty. If I ever take up bushwalking again I am going for insulated inflatable.... much more comfortable (expensive though).
If it is not inflating in one area then it is faulty. Two in a row is really bad luck as they are a good product.
FollowupID: 742944
Follow Up By: Rob! - Thursday, Oct 27, 2011 at 14:57
I think what Andrew is compaining about is not that the mat does not fully inflate but that part of the mat inflates and the other two-thirds remain flat with no air in it.
FollowupID: 742945
Follow Up By: asmithy - Thursday, Oct 27, 2011 at 15:41
Rob!
You have hit the nail on the head....
The top 1/3 of the mat near the valve has inflated to normal ,
BUT, the other (lower) 2/3 of the mat has not inflated at all.
It's flat and drawn out with wrinkles!!!
Andrew.
FollowupID: 742948
Follow Up By: The Explorer - Thursday, Oct 27, 2011 at 15:56
Yes, I think we all figured that bit out (mattress having uneven self inflation) but maybe if a small amount of additional air is blown in then the problem may go away....but as mentioned without actually seeing it I am not sure.
It is a just a suggestion and easy to try. Have you tried that - does the mattress inflate evenly when blown into? If it doesnt provide a fix then sounds like something is indeed wrong.
Also not sure the breath = moist air is a major probelm. If you use the matress in an area of high humidity not blowing into it wont eliminate issue - moist air will be sucked in anyway. Hence suggestion to leave unrolled and valve open when in storage.
FollowupID: 742949
Follow Up By: The Explorer - Thursday, Oct 27, 2011 at 16:14
From the therm-a-rest FAQ page.....
My mattress doesn’t seem to self-inflate. Is it defective?
Likely not. Although all of our foam-core mattresses self-inflate, (the NeoAir™ mattress does not have a foam core, therefore mouth-inflation is required) the extent to which they do is directly related to the properties of their foam. For example, our Camp & Comfort™ mattresses inflate incredibly fast because they use a much denser foam with a greater ‘memory’ of its uncompressed state. The ultralight, die-cut foams in our Fast & Light® mattresses on the other hand are chosen for their extremely light weight, trading off some self-inflation efficiency for ultralight performance and may require a few breaths to inflate fully.
If your mattress is new, or has been stored rolled or compressed for a significant amount of time, it could take up to 24 hours for the foam inside your mattress to fully regain its loft and maximum self-inflating efficiency. To help with this, we recommend inflating your mattress fully by mouth to help stretch the foam core back to its original loft.
FollowupID: 742955
Follow Up By: asmithy - Thursday, Oct 27, 2011 at 16:16
greg, mick & others,
as a last resort the supplier told me to blow air out of my mouth into it....
i have done this each afternoon for the past four days when bringing it inside from the sun....
the mat fully inflates no problem after about 4 big breathes but then goes down almost immediately when you take your mouth off the valve.
the foam doesnt appear in the bottom 2/3 of the mat to be inflated.
thanks for all you help guys, we'll see if something goes good today in the sun for a result.....
thanks again,
andrew.
FollowupID: 742956
Follow Up By: The Explorer - Thursday, Oct 27, 2011 at 16:23
Hi again,
If you want the air to stay in you have to close the valve while still blowing, otherwise, yes, the air will rush out. Its a bit tricky but just have the valve open a little bit and twist quickly shut with your mouth still on it.
Greg.
FollowupID: 742960
Follow Up By: Rob! - Thursday, Oct 27, 2011 at 16:27
There might be some air escaping but not so much that the mat becomes flat. It sounds stuffed. Get them to send you another.
FollowupID: 742962
Follow Up By: The Explorer - Thursday, Oct 27, 2011 at 16:46
You have to close the valve very quickly or a significant amount of air will escape and the air pressure required to stretch the foam core back to its original loft (in fastest possible time) may be insufficient. If you get it wrong the mat just wont be up to needed pressure. Mat maybe stuffed but based on information available possibility exists that it can be fixed - so try the suggested fix (properly) and see what happens.
FollowupID: 742970
Follow Up By: Member - Alan K (QLD) - Saturday, Oct 29, 2011 at 13:35
I had the same problem with a Spinafex 4WD mat and asked at a camping shop about it not fully inflating. Like many I stored mine rolled up. I was advised that the best way to re-inflate was to leave it out all day on hot concrete as that assists in flling out all the air passages. Seems to have worked.
FollowupID: 743130
Reply By: Pebble - Thursday, Oct 27, 2011 at 18:55
We purchased 4 self inflating mats, one pair was thicker at one end and the other pair for the kids were uniform. What we found was that one of the kids mats did not inflate at all, we returned it and got a replacement which was fine.
On a first decent camping trip thoug hone of our mats (the ones thicker at the heat end) does inflate fine but goes completely flat during the night, the other also loses pressure. They're both cheaper brands not Thermarest. I guess you get what you pay for, we will probably use the big bulky 4wd double self inflating mat, it's comfy even if the caps aren't closed!
I think with self inflating mats if they're left stored rolled up for too long the foam compresses too much and they don't inflate. It's always good to store them unrolled and valves open when not in use. We keep ours under the bed usually.
In your case if the foam inside has compressed too much I"m not sure if you can restore it, I would return it, besides if you have to blow it up or sleep on compressed foam you may as well buy an airbed!
AnswerID: 468657
Follow Up By: The Explorer - Thursday, Oct 27, 2011 at 19:37
"besides if you have to blow it up or sleep on compressed foam you may as well buy an airbed!"
Foam provides some insulation from cold compared to straight air, plus the thinner self inflating type mats (used by hikers/motorcycle riders for light weight/small space) generally do need a bit of a helping hand with some puffs anyway (because they are so thin), but thats a personal choice, some like it hard. Not sure if they make a non-foam mat for hikers? Yes, if Andrews mat is stuffed he should take/send it back.
FollowupID: 742978
Reply By: Pebble - Thursday, Oct 27, 2011 at 19:56
I agree with you there, I wasn't advocating that he should get an air bed, just that you do buy a self inflating mat because they do self inflate and have foam in them (as well as the other reasons you listed).
I personally let a tiny bit of air out of mine anyway, it's dear Husband that likes more comfort :) in which case the advantage of a bulky self inflating matress is that the foam doesn't get wet or dirty!
AnswerID: 468665
Reply By: ian - Thursday, Oct 27, 2011 at 21:33
asmithy,
I have another step to suggest
Blow it to as high a pressure as you can get it, and close valve without air escaping. THEN lie on it to push air into dead sections.
good luck
ian
AnswerID: 468677
Follow Up By: asmithy - Thursday, Oct 27, 2011 at 22:14
thanks pebble, ian and explorer ......
but after another day in the hot sun, rolling, unrolling, blowing up, closing the valve, opening the valve, blowing up and then lying on it,
guess what,
nothing has changed, still only the top 1/3 of the mat has inflated properly!
It will be going back in the post tomorrow unfortunately...
again, thanks all for all your help, lets hope a new the third mat might work??
cheers,
andrew
FollowupID: 743000
Follow Up By: The Explorer - Saturday, Oct 29, 2011 at 16:39
Bummer
One downfall of shopping online I suppose..you cant see what you're getting till you got it.
Good luck.
FollowupID: 743156
