jayco lift poles
Submitted: Saturday, Oct 29, 2011 at 23:07
peter m26
hi guys
I recently had trouble with my jayco
penguin lift cables and poles are couple of guys replied thanks fore the tips
I am pleased to report that i have found are way of replacing the two sliding poles without striping the interior of the van
You will need too remove the winch and cable covers then use are peice of wood to hold the roof up
mine was 850 mm long place it close to the lift pole then lower the roof so it resting on the wood, then wind the winch down about half are turn so the cable going to pole you are working on is just lose then remove the cable from the plate down near the winch tack note of the adjustment you will need to reset it later
now remove
the nut holding the top of the pole to the roof , slide it down in too the second pole then look at the lower pole in the body of the van you will see the guide bush there is are clip to push on the inner edge , push that in and use the second pole as are slide hamer to pop it out
SO SIMPLE
To reassemable pull the lift cable and the spring pops up place the 2 poles on the spring TACK NOTE THAT THE SPRING IS IN THE TOP POLES LOWER BUSH AND BOLT HOLE FORE THE ROOF IS IN LINE SLIDE IT IN PULLING THE CABLE TOGETER THEN REFIT LOWER BUSH AND TOP POLE TO ROOF REFIT CABLE TO WINCH AND ADJUST CHECK CAGLE ON ROLLERS , OK
Its easy
see u later peter
Reply By: Hairs & Fysh - Sunday, Oct 30, 2011 at 11:18
Thanks for posting Peter.
I'll keep that aside just in case I need to replace
mine or someone else has problems with theirs.
BTW, can I add a copy of this to my site, as it may helps others?
How to repair a Jayco Lift System
Thanks again for posting.
468859
Reply By: member - mazcan - Sunday, Oct 30, 2011 at 14:22
hi peter m26
you have worked out what others have known for a long time and full credit for your perseverance if you had of googled the topic it has been done to death on this site at least twice as
well as
www.popupportal.com
as far back as 25/6/2007-found 42 posts on this subject
pays to use google it is a great time/worry saver and volumes of imfo
but im not saying your thread imfo wont help others it spot on advice
barry
468869
