jayco heritage
Submitted: Thursday, Nov 03, 2011 at 21:50
ThreadID: 89892 Views:4521 Replies:3 FollowUps:3
just brought a 2005 heritage how do i find a manual need to remove the roof vents to repair fly wire and rubber also haveing trouble filling the back tank thanks mal b
Reply By: Member - Redbakk (WA) - Thursday, Nov 03, 2011 at 22:08
Image Could Not Be Found
Hi Mal......I used to hate trying to fill the tanks with water when at a road house because it took too long and I was holding up everyone else....so I modified my water filling with a snap lock fitting as you can see in the photo.
Now when I am at the road house I can quickly connect to the tap and I direct the water to which tank I desire to fill.
When the tank is full it over flows out the breather hoses which still are connected to the old fill points.
This mod works so well for me......I luv it.
AnswerID: 469161
Follow Up By: Member - Mal B - Thursday, Nov 03, 2011 at 22:19
thanks will look at your mod mal b
FollowupID: 743501
Reply By: Villatranquilla - Thursday, Nov 03, 2011 at 22:31
which roof vent ??- if its the center single hatch (not the 4 seasons hatch) just unscrew the four corner screws then there are 2 more hidden screws along opposing sides accessed through a hole. Replacement flywires frames available from caravan van supply shops. We too have trouble filling tanks so will look at the modification on the last post - it looks good
AnswerID: 469164
Reply By: Member - Redbakk (WA) - Thursday, Nov 03, 2011 at 22:43
Mal....just been out to the van and looked at the four seasons hatch and there is a instruction label stuck up there ( where you cannot see it inless you climb up) and it says.......INSECT SCREENS: remove by lifting off from top corner and peel off....may be washed.....replace by pushing onto track, start at the bottom.
Hope this helps.
AnswerID: 469166
Follow Up By: ozjohn0 - Friday, Nov 04, 2011 at 11:43
Good luck refiitting the flyscreens, They're a real bugger.
Soaking them in hot water to get them soft will help a 'little'.
ozjohn.
FollowupID: 743530
Follow Up By: Member - Mal B - Monday, Nov 07, 2011 at 20:19
thanks guys my hatch is a dometic the small one i beleave the bottom is cliped in you can repair it or replace thanks mal b
FollowupID: 743841
