inverter question
probly one for the gurus
the other day i asked about solar panels and inverters(running air con etc)
and it seemed like im dreaming so next question is.
can i conect the solar panels to the onboard battery via anderson plug.
run the inverter of the battery.
plug the onboard jayco type inverter(240 volt)into my new converter so all the power points will work in the van.small 240 volt things like tv/radio.
thanks for any info
ps inverter is 1200 watt.
Reply By: Battery Value Pty Ltd - Friday, Nov 04, 2011 at 19:47
yes you can connect the solar panels to your battery (recommended through a solar regulator), and run an inverter off that battery.
I'm not sure what you mean by this though
...plug the onboard jayco type inverter(240 volt)into my new converter ...
cheers, Peter
AnswerID: 469221
Follow Up By: nowimnumberone - Friday, Nov 04, 2011 at 20:13
when you plug the van into 240 volt van park etc.
there is an inverter that turns 240volt into 12 volt for the light etc.
sorry wasnt thinking about the power point thats a different thing.what i should have said
if im only using small things can i plug the inverter to run the van eg a lead from the inverter to the 240 volt inlet outside the van.
without damaging the jayco inverter/charger
im getting old and forgot to put half the question on lol
FollowupID: 743563
Reply By: Member - Serendipity(WA) - Friday, Nov 04, 2011 at 20:13
I think Peter has answered most of your question but I might add I think I know what you mean by plugging in your 240v. Like my camper it has an external 240v inlet so I can have 240v in the camper. Of course it is set up so that if I was in a caravan park I could then plug in. My camper then has a 240v built in battery charger, 240v outlets for both fridges to plug in, and a range of 240v spare wall plugs.
The only problem is you would be with solar powering your batteries, that then power your inverter, that then powers your camper's 240v wiring setup and if it is like mine you might have a battery charger powering your batteries again. That would be circular logic.
I have a solar panel on my camper, that runs through a regulator to power my batteries. Then I do have an inverter (1000w) fitted in my camper that I can plug 240v appliances in. I choose to only use the one outlet from the inverter as I am very wary of 240v when out camping away as the inverter is not running through an earth leakage or RCD - it is plain raw 240v and I need to be careful with that when camping. I even have a large isolator switch attached to my inverter so it won't accidentally get switched on.
It is handy having and inverter for those appliance I don't have 12v adapters for.
Serendipity
AnswerID: 469225
Follow Up By: nowimnumberone - Friday, Nov 04, 2011 at 20:25
thanks that what i meant.
so if the inverter was plugged into the van from the outside inlet
i know my onboard jayco inverter would be trying to charge the battery im using the inverter off(im confusing myself)but if im only using low wattage 240
volt things for a short time and then solar?genny charge would that be ok.
reason being daughter likes a movie before bet and we like to listen to back ground radio and i dont want leads running all around the van and i dont want to run a gennie.
FollowupID: 743565
Follow Up By: oldtrack123 - Friday, Nov 04, 2011 at 20:34
Hi Serendipity
RE:"I have a solar panel on my camper, that runs through a regulator to power my batteries. Then I do have an inverter (1000w) fitted in my camper that I can plug 240v appliances in. I choose to only use the one outlet from the inverter as I am very wary of 240v when out camping away as the inverter is not running through an earth leakage or RCD - it is plain raw 240v and I need to be careful with that when camping. I even have a large isolator switch attached to my inverter so it won't accidentally get switched on."
Congratulations
You are aware of the risks & follow recommended practise
FollowupID: 743566
Follow Up By: oldtrack123 - Friday, Nov 04, 2011 at 20:46
RE :"nowimnumberone posted:
cheers"
Sorry, but I am having difficulty uinderstanding your aim
But I will just make these points
The inverter should not be plugged into the van inlet, it will attempt to run anything that is switched on as Peter has explained
It has an added risk of possible electric shock under certain fault conditions & your RCD is not operational
It also breechs a basic safety rule when using such devises
THAT RULE IS "NEVER CONNECT MORE THAN ONEclass 1 devise @ any time "
A class1 devise can be assumed if it is fitted with a 3pin plug. when the van is connected it itself becomes that FIRST class1 devise
If you must use an inverter connect it straight to the battery& only use ONE class1 devise @ anytime.
You may use multiple class2 devices [2pin plug] direct from the inverter with a high level of safety.
FollowupID: 743568
Follow Up By: Battery Value Pty Ltd - Friday, Nov 04, 2011 at 21:04
Hi numberone.
So you've got an inverter running off the battery which then gets charged by the inbuilt charger which receives power from the inverter.
There's no problem with that except for the battery to see an extra drain (on top of the DVD player and radio drain).
How much extra drain depends on the rating of your battery charger.
Multiply the inverter's and charger's efficiencies, say 0.8*0.8 equals 64%, so you're wasting 36% of charging power.
Say it's a 10A charger (140W), then the battery sees an additional drain of 50W, or 4 amps.
I'm wondering, isn't there an on/off switch on the battery charger?
cheers, Peter
FollowupID: 743572
Follow Up By: nowimnumberone - Friday, Nov 04, 2011 at 21:22
sorry about the confusion
the battery charger im talking about is the one that jayco fit setec inverter.
im not running any other charger.
if i was to run a lead from the inverer (new one i bought) to the outside 240volt inlet on the van the setec runs automatically so the 12 volt lights work.
so if the new inverter was plugged into the van the setec will be charging the battery automaticaly.
if all the other power points fridge/microwave/hot watter system were unplugged the only thing running would be what i plug in tv/radio.
looking like i might have to run leads etc the thing im trying to avoid
FollowupID: 743576
Follow Up By: Battery Value Pty Ltd - Friday, Nov 04, 2011 at 21:38
that's ok numberone,
I think it's all understood.
The battery charger is built in and always charges the battery if 240V comes in from the outside.
So if you 'make' 240V from your battery (by inverter), and use part of the 240V power to 'charge' your battery, then this portion of battery power is on a mary go round trip.
Every time it passes the inverter/charger combo, it loses 34% of substance.
But because the built in battery charger keeps its charging power constant, the battery sees 34% of extra drain caused by the charger feeding back to the battery via the inverter.
There's no problem with this, except for the battery seeing an extra load of about 4 amps.
If you could somehow turn off the built in battery charger, then there'd be no wasted battery energy.
Does this make sense?
cheers, Peter
FollowupID: 743578
Follow Up By: nowimnumberone - Friday, Nov 04, 2011 at 21:47
yes it makes sense.
the setec charger can be unpluged/switched of but i wont have any lights.
but thats ok were outside at the fire and daughters watching dvds.
so is what im thinking doable.
and can you see any problems with what im thinking.
thanks again
FollowupID: 743581
Follow Up By: Battery Value Pty Ltd - Friday, Nov 04, 2011 at 21:59
Yes numberone,
turn off the charger.
BTW, if you've got 240V inside the van (supplied by the battery/inverter), you can use any power saving 240V light source, can't you?
cheers, Peter
FollowupID: 743582
Follow Up By: nowimnumberone - Friday, Nov 04, 2011 at 22:10
no all the light in a jayco are 12 volt
i could get a 240 lamp if needed and use an energy efficiant globe
thanks again
FollowupID: 743585
Follow Up By: Battery Value Pty Ltd - Friday, Nov 04, 2011 at 22:28
yes, any plug in type 240V lamp, maybe a compact fluro.
And last but not least:
You've noticed the other posters' warnings about using 240V from an inverter.
Because one of the 240V wires inside the van, or in the appliances connected to it could develop a short with the van's structure, the other wire would then become 'hot' or 'life'.
In case someone touches that wire, there's potential for a fatality.
cheers, Peter
FollowupID: 743587
Reply By: Member - Serendipity(WA) - Friday, Nov 04, 2011 at 23:34
I think everyone has sort of answered you question.
Maybe you could look at what I have done. For a TV we bought a small flat screen Grundig TV with built in DVD player.Well when I got it home I found out it is actually a 12v TV and has one of those small 240v to 12v power packs to plug it in at home. Also in the box was a plain 12v lead to a cigarette lighter. So now we can use it at home or in the camper.
I was surprised at this and the looked around and found almost all the 240v appliance you have at home can be bought from caravan shops as 12v appliances.
The only times I use my 240v inverter is a few appliances I have not got around to buy as 12v. Like my computer - I know you can get a 12v cable just need to do it. My hand held UHF charger. A few other bits and others I camp with use it for their gear as well.
For camping I think you might be confusing things by trying to plug you camper into the same power as it is producing.
Serendipity
AnswerID: 469236
Reply By: Motherhen - Saturday, Nov 05, 2011 at 00:12
Hi #1, although our set up is different to yours, we also have 12 v lights only, with the power outlets being 240. With solar, there is always enough power for our lights, however i do carry a 240 v lamp and have used this on mains power when a light tube failed - two of them would light up the entire van.
AnswerID: 469238
Reply By: Member - Vince M (NSW) - Saturday, Nov 05, 2011 at 19:08
you have not said what type of inverter you have, & some appliance's work better (safer for the appliance) on a pure sine wave type
AnswerID: 469284
Reply By: The Bantam - Sunday, Nov 06, 2011 at 00:18
lets get all this clear.
you have a n inverter that makes 240V from 12 volts, that you wish to run you vans 240V system off.
you also have an inverter bassed battery charger that charges batteries from 240V.
If this is all there is to it, you need to switch this battery charger off or you will be running a circular process that will be wasting energy and putting extra load on the inverter.
As for some appliances running better off pure sinewave inverters....this is a greatly over stated issue.
The vast majority of appliances will run very happily off modified sinewave inverters.
AnswerID: 469302
Follow Up By: Member - Duke (TAS) - Sunday, Nov 06, 2011 at 18:32
I think you will find that what he is talking about is a Converter. Converts 240 back to 12volt. Thats how the Jayco i owned was set up. As Pauline would say PLEASE EXPLAIN??
Duke
FollowupID: 743763
Follow Up By: The Bantam - Sunday, Nov 06, 2011 at 23:39
The term "inverter" ( or converter for that matter) in electronics can cover a vast number of electronic devices for a vast number of purposes.
We have inverters that are intended to produce 240V AC from 12 or 24V DC
WE have battery chargers that use inverter technology to make a DC charging voltage from 240V rather than conventional transformer bassed technology.. they are probably best called battery chargers.
We have "Inverters" in airconditioners that allow the motor speed to be continuously varied.... in industry we would call them "variable speed drives"
In fact in this day and age the majority of the power supply units in electronics are in fact inverters or as we would more frequently call them "switch mode power supplies"
There are some realy funky and complicated devices that go under the name of "inverter"..like universal power supplies that will take almost anything from a variety of sources and output the desired usefull voltage.
This " inverter" word is getting pretty commonly used for all sorts of things so we are wise to investigate the function of any device called an "Inverter" before we draw any conclusions.
FollowupID: 743775
Follow Up By: Member - Duke (TAS) - Monday, Nov 07, 2011 at 15:11
Thanks for the heads up Bantam, i am afraid all this Technology is leaving an old Fart like me behind.
Cheers Duke
FollowupID: 743807
Follow Up By: The Bantam - Monday, Nov 07, 2011 at 15:30
Don't be afraid of the "technology", Just ask one simple question.
What does this thing do?
And forget about all the hype and fancy words.
FollowupID: 743809
