Help needed converting a gas valve from natural gas to propane
Submitted: Saturday, Nov 05, 2011 at 12:49
ThreadID: 89917 Views:4588 Replies:6 FollowUps:6
Hello to everybody! I have a Warm Morning stove (incinerator) which works on natural gas. I really need to be able to use it with portable propane tanks for using outdoors. I've been told that the valve is adjustable between nat. gas and LP, however I don't know how to do it. I'd appreciate some advise. The valve is old and doesn't appear in any modern catalogs. I checked in a couple of gas parts shops today. I would gladly buy a new replacement valve for propane, but don't know which model matches my current old valve. My valve is ITT General Control (V300) H202A182, made in the 60s. Please help me figure out how to do the conversion.
Reply By: Motherhen - Saturday, Nov 05, 2011 at 12:57
Probably a legal requirement to have it done by a gas plumber.
AnswerID: 469262
Reply By: Member - Tony H (touring oz) - Saturday, Nov 05, 2011 at 13:00
Maybe ask some questions here http://www.ask.com/questions-about/Warm-Morning-Stoves
AnswerID: 469264
Reply By: Member - allan t (NT) - Saturday, Nov 05, 2011 at 14:10
HI Ranis5 Could be wrong I
think you have to change the jets as well
Alllan
AnswerID: 469267
Follow Up By: ranis5 - Saturday, Nov 05, 2011 at 15:23
I never thought this would be such a big problem. Local plumbers refuse to do it, local plumber supply shops have no idea what this is (when I show them the valve and ask for replacement on propane). I think the jets (orifices) don't matter as long as the valve is converted to the proper pressure of propane. I'm thinking I will just use the valve as is. I will simply turn the propane regulator on the propane tank very slightly to compensate for the higher pressure of the propane gas. I'm pretty sure those propane tanks are safe enough to try this.
FollowupID: 743653
Follow Up By: Member - Tony V (NSW) - Saturday, Nov 05, 2011 at 15:51
I agree with Allan, the jets will need replacing.
Its not the higher pressure but the higher calorific value of a propane/butane gas that matters.
Could be time to check life and any other insurances you have.......
FollowupID: 743661
Follow Up By: Bigfish - Saturday, Nov 05, 2011 at 16:48
Mate..do yourself and those around you a favour. 40+ year old valve..BIN IT.
If you have to use the unit then change the ENTIRE gas sytem over. Depends how much value you put on yours and other people lives.
FollowupID: 743666
Reply By: TTD1 - Saturday, Nov 05, 2011 at 20:20
ranis5,
You need to replace both the regulator with an LPG one and the jets in the appliance.
Natural gas operates at .75kpa and LPG operates a 2.75kpa pressure at the jet orifice.
We did hundreds of these appliances when the old town gas was replaced with LPG and the older units were far better than the new ones once converted.
A good gas fitter should be able to put you right.
TTD
AnswerID: 469287
Follow Up By: The Bantam - Saturday, Nov 05, 2011 at 22:06
I am no gass expert, but aparantly there is an issue changing between gass types...if the gass, the jetting and the preasure don't match, a situation I know as " gassing out" can occur, where the flame stands up off the burner and excess unburnt gass can escape....thus potentially causing an explosion or axphixiation.
There is a famous case where a fat indian stewed himself in his own bath..after incorrectly rigging up a gass ring to heat his bath water warm.
they think, He fell asleap and died from asphixiation, while the gass burner stewed his body till the gass bottle ran out.
the story goes that when they found him there was a thick layer of congieled fat on top of the bath water with the shin bones & feet sticking out.
The place must not have blown up because the correct mix ratio did not occur.
Serioulsy don't mess arround with running stuff off the wrong gas.
FollowupID: 743701
Follow Up By: dozer49 - Sunday, Nov 06, 2011 at 09:30
The advice given so far is spot on. Bin It. if its 40 year old gas equipment, it should have been replaced 20 years ago!
A story comes to mind of a bloke on his first parachute jump.
He jumped, pulled the rip cord and nothing happened.
Same thing with the emergency chute.
As he raced to earth, he was amazed to see another bloke coming up,
as fast as he was going down.
"what do ya know about parachutes?" he asked as they passed.
"Bugger all", came the reply followed by "what ya know about gas BBQs ?"
FollowupID: 743716
Follow Up By: ranis5 - Sunday, Nov 06, 2011 at 10:50
Sigh, ok. I don't want to be going up like that. But I really wanted to see how this device does work. It can be used like a small incinerator, and that is why I had it shipped from Kansas to Massachusetts a few months ago. Had some hard time finding it on Craigslist before that. And now after all investments and troubles and waiting all that's stopping me is the LP conversion. I never thought this would turn into such a problem. Of course I would happily bin the valve if I only could find a modern replacement. I took the valve with me to different gas plumber shops in the area. Most of them wouldn't sell to not licensed individuals like me, and in the one shop who does sell to everybody they could not find a replacement in a 500+ page catalog. Searching under the brand and serial number of the valve on their computers also brought nothing.
OK, thanks for all advice. If anybody has an idea I didn't think of, you can always email me - at_grigorov@yahoo.com. I'd gladly pay to a qualified person to either convert my current valve or help me find a replacement for propane. I'm freezing the project till then, won't be trying to become accidental astronaut.
FollowupID: 743721
Reply By: Bill BD - Sunday, Nov 06, 2011 at 10:04
There was a gas death here (WA) yesterday. No details yet but I believe it was bottled gas. Some good advice has been given here. Bin it or at least get it changed over legally.
AnswerID: 469313
Reply By: Member - John and Lynne - Sunday, Nov 06, 2011 at 10:35
It sounds as if you are well on the way to making a very efficient bomb. Who are you planning to camp near? Lynne
AnswerID: 469315
