Tuesday, Nov 08, 2011 at 00:18
It all depends on what your expectations are.
Do you expect your fridges to run continuoulsy without any outside charging and for how long.
how is your fridge situated as far as being in a cool place.
How deep do you expect to cycle your battery and how long do you expect it to live.
All this stuff comes down to ho long a piece of string is.
How about you start with finding out exactly how your existing fridge actually performs in the current set up.
I doubt very much that even with the existing set up that you will be reliably 100% solar self sufficient, I recon two cloudy days in a row and you'll be
well bugered.
First thing to establish is how long the existing fridge (Fully loaded and pre chilled...bottles of
water will do) will run from the existing fully charged battery till the low voltage cut out drops its bundle.
Then you can hook up the solar pannel and see how it travels.....
Once you have done that give it a run as a frezzer 3/4 full icecream containers of
water is a suitable load.
all this you can do at home
I trust you have a good digital voltmeter so you have some idea how things are going.
You can fiddle about with different fridges, better insulation and all sorts of foolishness, but the fact remains " ya can'a change the laws of physics, Jim".
The bottom line is that if ya want to run big fridges, you need to run big batteries and a pretty solid source of charge.
Now how about a punt.
As a very rough guess on your existing set up, I recon you will get 2 to 3 days run time out of the battery tops, with use of the solar pannel under conditions that are in your favour ya might extend that run time to 5, 6 or more days, but if you have a couple of cloudy days or even worse rain all bets are off.
As I said......If you get 24 hours out of it as a freezer on the battery unaided I will be most surprised.
Give it a try..see how close I am.....no cheating mind..remember the maximum safe temp for a fridge is 5 deg C for a fridge and -15 degC for a freezer.....
743851
