Taipan XP Exhaust & DP Chip
Submitted: Monday, Nov 07, 2011 at 13:51
Patrol GU VI
I am looking at getting a Taipan XP exhaust system and a DP chip installed on my 2008 Patrol 3.0l Common Rail Diesel 5sp Manual.
Has anyone had these units installed on their vehicles and what are the pros and cons of them? How much difference does it makes for city/highway driving, towing and 4WDing?
Also, Does anyone have power torque figures for before and after results?
Reply By: Member - Scott & Gaby (Canada) - Monday, Nov 07, 2011 at 14:52
Had some great results on the VDJ79 and have covered it in my blog here. Would recommend steering away from the standard plug and play
fuel pulse type chip and getting a comprehensive tuning ship. Time spent on a dyno is never wasted. Also plan on including an EGT Guage as part of the package.
CHIP & EXHAUST RESULTS
Mick (using Scott 'n Gaby's profile lol)
469396
Reply By: Member - Joel and Michelle (WA - Monday, Nov 07, 2011 at 17:38
G'day Patrol
Had the DP chip in my 2004 3.0l Auto and was very happy, so happy that I put one in my 100 series TD. The 3 inch exhaust came later and whilst I don't have the dyno figures. The exhaust seemed to make as much difference as the chip in the Cruiser.
Joel
469406
Reply By: DIESEL22 - Friday, Nov 11, 2011 at 12:03
Have some info that may interest u on the chip and exhaust.
My '09 CRD 3ltr has been fitted out with a Steinbauer Chip and Taipan exhuast. A Dawes Valve was also fitted to prevent any undected spiking. I also have a factory fitted
snorkel (I have also read on other sites that these do not do any favours for economy. True or False - I dunno). Upgrade was done by
United Fuel Injectiuon in
Perth. They be one of the leaders in this field. As explained to me at time of fitting, you will definately get more power but economy increase, if any, only comes with the way u drive it. Following are some figures that I have come up with from a log that I have run since buying the car new. Upgrade done at 13K. Now completed 40K (15K of which was heavy towing).
PRE UNGRADE (TAKEN AFTER 8000KMS DUE TIGHTNESS OF VEHICLE). ALL FIGURES ARE AVERAGED.
Economy: City/Hwy (normal load) 8.1 kms/ltr 12.3 ltrs/100kms
POST UPGRADE
AS U CAN SEE - NO DIFFERENCE (I am also a sedate sort of driver)
Economy: Country (all conditions road & weather) towing a Caravan weighing in at 2400kg when loaded. Worked on 15K of use:
5.3 kms/ltr 18.8 ltrs/100kms (Avg spd 85-95kph)
POWER: There is a definate increase in power, especially noted when towing in a hilly environment, not noted as much on the flat but obviously is there. Not too many rigs of similar size can keep up with me in the hills. Incidentialy, got done by camera, fully loaded going UP Greenmount
Hill (outskirts of
Perth) doing 81kph (70 zone). Good start for a half block trip around, only left home half hour before.
DYNO FIGURES:
PRE UPGRADE 98KW (133HP) @ 3223RPM 315NM @ 2317RPM
POST UPGRADE 123KW (167HP) @3475RPM 364NM @ 2569RPM
Hope all that helps in making decision
469749
Follow Up By: Patrol GU VI - Sunday, Nov 13, 2011 at 13:41
Thanks Diesel, That is very helpful information and exactly what I was after.
I did notice with your dyno figures that the peak power/torque figures were produced at a higher RPM Post upgrade. Do you have to rev you truck harder now to get that peak performance? What is it like low in the rev range?
744354
Follow Up By: DIESEL22 - Sunday, Nov 13, 2011 at 19:06
Hello Patrol GU
Figures given are direct off the chart supplied by
United Fuel.
Of revving the truck harder I would say NO. What u do notice and I picked it up straight away was that from a standing start, I was going thru the gears faster, obviously getting up to cruising speed faster.
Of getting to peak performance figures , these be cutting in pre cruising, dropping down to overtake or goin up hills in a lower gear.
Not realy taken much notice of difference in the Low Rev range i.e. FWD.
Of the economy figures I have given previously, the RPM is between 2050 - 2250 (5th gear). There is plenty in reserve for passing etc. Yes I do use 5th when towing, but only in selected conditions (if the motor sounds good, all is good).
DIESEL22
744379
