Child Safety Seat to Cargo Barrier Connection
Submitted: Monday, Nov 07, 2011 at 17:23
Member - Rob D (NSW)
I have a Blackwidow cargo barrier with a divider and shelf. These are bolted to the Blackwidow drawer system in the rear of my 100 series Landcruiser.
I would like to be able to take my grandchild with me and need to work out how to safely attach the child safety
seat to the cargo barrier.
I am sure someone else has done this before. Any suggestions?
Reply By: Rob! - Monday, Nov 07, 2011 at 17:37
I've heard of people placing a steel bar across the back of the barrier and attaching the
seat to that. Having said that, I would think that there isn't a safe way to attach a child
seat to a cargo barrier. If somebody has done it, ask them how it performed in an accident. I'd get it done professionaly.
469405
Reply By: Hairs & Fysh - Monday, Nov 07, 2011 at 17:40
Hi Rob,
I don't know if the 100 is the same as some 80's, but
mine as a set of bolt holes in the roof just inside the cargo area. The strap then passes through the barrier.
I've a GXL, I believe the standard
barn door model don't have them.
Just pull your hood lining rubber back and have look.
Blokes with 80's and barriers have done it this way.
Hope this is of some help.
Cheers.
469407
Follow Up By: Member - Rob D (NSW) - Monday, Nov 07, 2011 at 19:25
Thanks Jon & Karen,
I had a look and could not see any obvious bolt holes. The manual shows some attachment points on the floor just where the drawers are.
743830
Follow Up By: Hairs & Fysh - Monday, Nov 07, 2011 at 19:55
Hi Rob,
It was worth a look, I'm not at all familiar with the 100, but thought I'd mention it anyway.
I thought I knew the 80 pretty
well, amazing the bits and pieces that I've discovered myself or from others that have found things hidden away under carpet or behind plastic molding that has never seen the light of day and their not in the Factory workshop manual.
Good luck with and I hope you find a solution.
Cheers.
743837
Reply By: andoland - Monday, Nov 07, 2011 at 18:01
Rob,
My blackwidow drawers have the child restraint hooks attached to them. All they do is drill a hole through the front wall of the drawer case and bolt through the proper hooks for the child restraint. If yours don't have them already I'm sure you could buy the hooks from them and get them to tell you exactly where to drill the holes.
469409
Follow Up By: MrBitchi (QLD) - Monday, Nov 07, 2011 at 18:07
Is that certified??
743820
Follow Up By: andoland - Monday, Nov 07, 2011 at 18:11
Yes, when supplied by Black Widow. It is something you can order at the time of purchase. I was expecting something more than just a hole drilled with the anchor bolt supplied but that is all there is to it, hence my comments that you could easily drill the hole yourself, if you have the correct location, and install proper anchor bolts.
743821
Follow Up By: Member - Rob D (NSW) - Monday, Nov 07, 2011 at 19:27
That is useful to know. I will approach Black Widow to see if they can retro-fit one.
743831
Follow Up By: SDG - Monday, Nov 07, 2011 at 20:05
Outback also do the same. A hole drilled in the front of it with an anchor. Need to request this at time of ordering. I don't think they retrofit, but it is not hard to drill your own hole if you could find out where the company does it.
743840
Reply By: MrBitchi (QLD) - Monday, Nov 07, 2011 at 18:05
Attaching it to the cargo barrier is a no-no. You have to attach to an approved restraint point, either the original ones or have aftermarket ones fitted and certified. Had a shorty Pajero once that had no restraint points and had to have a bar fitted across the back to which the child
seat was connected. PITA as the bar went straight across the back, full width at window height...
469410
Follow Up By: Hairs & Fysh - Monday, Nov 07, 2011 at 18:17
Hi John,
I was just ready through some threads in Lcool on 100's, couldn't find anything about there being anchor points in the roof, but there was a thread about how the third row
seat anchors are NOT rated for the child restraints, weird but true. The guys also mentioned how there are some dodgey setups, attached to draws and cargo barriers.
Rob,
I reckon a phone call to the RTA, I know, they'll send you around in circles and have you jump through hoops, but at lest you'll get the right answer, maybe ;)
743822
Follow Up By: Member - Rob D (NSW) - Monday, Nov 07, 2011 at 19:29
I will try Black Widow first. I can not imagine that they would fit them if they were not approved. They would be leaving themselves open to litigation.
743832
Reply By: ChrisE - Monday, Nov 07, 2011 at 19:31
Although I have a Patrol, I have black widow drawers and half cargo barrier and divider. There are nuts built into the drawers to attach the child
seat anchors to them on the front vertical face, just fold down
seat backs and check your drawers for the same. As above dont attach anchor to cargo barrier. In my previous patrol I didnt have drawers and the cargo barrier had holes in it so the
seat straps passed through it and I had anchors points put in the floor professionally. I have also seen spreader bars put in across old falcon wagons at rear
seat height, similar to what was mentioned above, but doubt you'll need that with the drawers.
469418
Follow Up By: Member - Rob D (NSW) - Monday, Nov 07, 2011 at 19:38
I did have a look for that; I did see some captive nuts, but they did not seem to be large enough to anchor a child
seat. I may be mistaken, I will have another look.
743835
Follow Up By: Member - Rob D (NSW) - Monday, Nov 07, 2011 at 19:58
Hi ChrisE
I just had a look again and the captive nuts are 6mm. The ADR34/01 calls for a 5/16" UNC bolt which is almost 8mm diameter.
743838
Reply By: Member - Craig F (WA) - Monday, Nov 07, 2011 at 22:12
In WA we can contact "KID Safe" they will check off or install your
seat for a nominal fee. Was very cheep. In WA you can also go to the companys that modify the cars for the mines and they have kits that can be installed to most cars that comply with the ADR's they will install and up-date your compliance plate with the attachment.
I dare say NSW will have something similar.
Craig
469426
Follow Up By: Member - Rob D (NSW) - Monday, Nov 07, 2011 at 23:07
Thank you Craig, I now have a few different avenues to explore.
743850
