fridge door
Submitted: Monday, Nov 07, 2011 at 19:42
peter m26
Hi guys
I have are 2010 jayco
penguin , i am having trouble with the fridge door it doesn't seem to lock properly , are lite pull on the door and it pops open
any ideas
peter
Reply By: Glenn_cot - Monday, Nov 07, 2011 at 20:54
You can adjust the hinges on the door so that the door sits a little higher and locks I did it to
mine and it fixed the problem.
Glenn
469422
Reply By: Member -Dodger - Tuesday, Nov 08, 2011 at 15:21
Glen is right.
Take the top pin out that is part of the hinge lift door off bottom hinge then add a washer of the required thickness to bottom pin and then re install door.
Sometimes it may be a bent bottom hinge if so very gently straighten it.
469485
Follow Up By: peter m26 - Friday, Nov 11, 2011 at 19:39
thanks Glen and Dodg
I will try your tips on the weekend
cheers peter m26
744209
