Jackaroo Question..
Submitted: Tuesday, Nov 08, 2011 at 10:31
Member - Oldbaz. NSW.
As the ever reliable Jack is approaching a timing belt service, I would appreciate input
re the possible service/replacement of a
water pump at the same time. I recall reading
that this was an opportune time for same. I dont intend doing it myself but would like
to give my mechanic a heads up on what may be required. 3.5L V6 petrol.
cheers.....oldbaz.
Reply By: Bushranger1 - Tuesday, Nov 08, 2011 at 10:48
G'Day,
I cannot give specifics as to the Jackaroo but I used to change the timing belt on the Hilux myself & would always do a coolant &
water pump change at the same time. Much easier to access the
water pump while the covers are off for the timing belt.
Also good insurance to change the timing belt idler pulley & tensioner puller as
I did not change the pulleys on a car I used to own & the pulley bearings siezed resulting in broken timing belt & a $600 towing fee! Luck would have it that no valves hit the piston.
Stu
469445
Follow Up By: Bushranger1 - Tuesday, Nov 08, 2011 at 10:52
It just occured to me that your Jackaroo is a petrol engine.
Many petrol engines use a timing chain rather than a belt. This does not need changing if this is the case. Not sure which system the Jack uses.
743860
Follow Up By: Member - Oldbaz. NSW. - Tuesday, Nov 08, 2011 at 10:56
G'day Stu, thanks for that..it was my intention to fit new idler & tension pulleys as
well as the belt..just didnt know about
water pump.......oldbaz.
743861
Reply By: Member - Noldi (WA) - Tuesday, Nov 08, 2011 at 11:30
OldBaz,
Had my
water pump changed at the same time (as
well as the tensioners and a few other bits and bobs), One of the club members (holden 4WD WA) didn't and had to replace the
water pump 12 monthe later.
rgds
469451
Follow Up By: Member - Oldbaz. NSW. - Wednesday, Nov 09, 2011 at 09:13
Thanks Ian..seems the right way to go..cheers...oldbaz.
743949
Reply By: wizzer73 - Tuesday, Nov 08, 2011 at 23:31
Yes it is an opportune time to get the pump done and the mechanic would probably suggest it too.
I bought a timing belt kit and
water pump off ebay when my 3.5 jack was due for a belt. Have a search on ebay for the 2 items to get some prices. Was alot cheaper that way. Then just gave them to my mechanic to install.
wizzer
469516
Follow Up By: Member - Oldbaz. NSW. - Wednesday, Nov 09, 2011 at 09:12
G'day Wizzer, had a chat to my mechanic & he is checking prices for kit & pump.
I'm no stranger to Ebay ,so will go there if other quote is exessive.Thanks......oldbaz.
743948
Reply By: Isuzumu - Wednesday, Nov 09, 2011 at 14:48
Hi Oldbaz, when I do the timing belt on the MUs I also make sure it is time to do the other belts, plus it is easier to do if you have the radiator out and give it a flush at the same time.
469555
