Solar - please enlighten me!
Am hoping someone can give me the benefit of their solar knowledge 'cos I haven't got a clue!!
I have ordered a van that comes with 2 x 90W panels (fixed to the roof) which run via a solar controller to help charge the 2 x 100Ah AGMs onboard. I also have a 2 x 50W folding set up with a Plasmatronics 12V 10A regulator attached.
I am wondering whether it is OK to plug the portable panels into the Anderson plug on the drawbar to boost my solar capacity. Can this damage anything, overcharge or whatever??
Thanks and cheers
TG
Reply By: Steve M1 (NSW) - Tuesday, Nov 08, 2011 at 13:24
should be fine with controller/regulator to look after any over-charging. I had a similar set up with previous van.
AnswerID: 469473
Reply By: Hamontheroad - Tuesday, Nov 08, 2011 at 13:56
If you use the Anderson plug to connect to the vehicle while mobile then there should not be a problem with plugging in the two 50w panels as they will only be pumping around 6amps at full sun. The charge controller will prevent overcharging the AGMs.
AnswerID: 469478
Reply By: Robin Miller - Tuesday, Nov 08, 2011 at 14:56
Probably ok TG.
There is though the possibility of the two seperate solar controllers being set to different voltages, as different types of batteries can have different optimum settings.
The settings are usually not very different but its worth checking the settings on the controllers first.
Specifically ask the van supplier for battery and setting info for their product - sometimes they don't even know or a proper setup gets overlooked.
AnswerID: 469482
Follow Up By: tg123 - Tuesday, Nov 08, 2011 at 15:36
Hi Robin
Does this mean that the solar controller supplied by the van manufacturer could have different cut in/ cut out voltages than those of the Plasmatronics regulator? If so, what are the implications of this please. If not then I need some help with an explanation :)
TG
FollowupID: 743889
Follow Up By: Robin Miller - Tuesday, Nov 08, 2011 at 16:00
Hi TG
Yes thats a reasonable way to state the issue without getting to technical.
There are then several possible senarios , mainly
1/ both controllers are set the same and to low - batteries won't get fully
charged.
2/ Both are set the same and to high - batteries may be overcharged depending on type.
3/ The controllers are set to different outputs - In this case the lower one will be under utilized.
Many accessories in these low volumne markets just get purchased and installed by the supplier with the manufacturers default values - so I suggest one asks specifically questions like "What type chemistry does the battery you supply use and has the controller been set for it , also could you write that setting down in the products manual please "
The response will act as a guide to how the rest of the van should be checked out !
FollowupID: 743893
Follow Up By: tg123 - Tuesday, Nov 08, 2011 at 16:30
Robin - I've lifted the info below from Plasmatronics website. It would suggest to me the regulator on my portable panels is suitable for charging AGM batteries (?) The solar controller in my camper trailer was able to be set for different battery types so am assuming the new one in the van should be similar and will be set to AGM. If this is the case, can you see any problems with overcharging occurring?
If I've got this completely wrong (very likely!!) please feel free to set me straight!!
TG
PR1210L 12 Volt 10 Amp Regulator
FOR SEALED OR GEL LEAD ACID BATTERIES
A simple two stage regulator for charging sealed or gel lead acid batteries from
photovoltaic panels.
SPECIFICATIONS
Boost Maximum 14.2 V
Boost Cut in 12.5 V
Float Maximum 14.0 V
Float Cut in 13.4 V
All voltages +/- 0.1 volts
Charge Current 10 A
The PR1210L is not adjustable.
FollowupID: 743902
Follow Up By: Battery Value Pty Ltd - Tuesday, Nov 08, 2011 at 18:31
Hi TG,
sorry for butting in, but I feel that the PR1210L isn't the best regulator for charging AGM batteries which have a boost charging requirement of 14.4 to 14.8V based on 25 degree ambient, with a temperature coefficient of -240mV/degree.
The boost voltage should be 'seen' by the battery for about 1~2 hours on a daily basis, if the SOC drops below 90% the night before.
But this controller has no brains so that it can't actually measure any time intervals/segments.
All it does is wait for the battery voltage to hit 14.2V briefly and then it goes straight to float.
For float charging, this controller cycles between 13.4 and 14V, averaging at 13.7V which is kind of ok, although still not perfect because of the lacking battery temperature compensation and the crude on/off regulation which is the most inefficient way of raising the SOC.
This regulator makes the battery work best, if it's not discharged too deeply, say 30~40%, because it can't supply the crucial 5~10% over-charge necessary to bring back a reasonably deeply discharged battery to 100% SOC.
A controller like this one shortens battery life by about 30 to 50% depending on a number of operating conditions.
So instead of 6 to 8 years your battery may last only 3 or 4.
For any other questions, just contact us through our profile.
cheers, Peter
FollowupID: 743912
Follow Up By: Robin Miller - Tuesday, Nov 08, 2011 at 20:22
Hi Tj Peter
I was going to say that the Plastronics 1210 is a pretty simple device , you can't go much wrong using it , agree with Peter that there are better items around , but suspect that the unit that comes with the van is probably a simpler device also and much the same as the 1210 so the 2 units , while not optimum will get along ok.
FollowupID: 743916
Follow Up By: Battery Value Pty Ltd - Tuesday, Nov 08, 2011 at 20:50
Hi Robin,
there's still hope that the OP's other regulator has better specs in which case the battery would benefit from it.
BTW, what's this Tj? Or did you mean to type TG? Just curious ;)
@TG,
it's good to have the choice of selecting battery type on the regulator.
But it's better to actually measure the voltage, and then decide which 'chemistry' to select.
That's for two reasons: number one is that a great majority of solar regulator manufacturers don't know much about batteries hence assign the wrong setpoints to the individual chemistries.
Number two is the inaccuracy of the built in voltage reference.
A reasonably accurate voltage reference with 1% accuracy can be 10 times more expensive than a reference with 4% accuracy.
But in a 12V environment, 4% is almost 0.5V which explains why the setpoints can be all over the place on some regulators.
So how do you select the right 'chemistry'?
First find out what your battery manufacturer's recommended charging end voltages are for the float and absorption stages.
Then you need to measure the battery voltage using a multimeter (even the cheap ones are reasonably accurate for this).
Battery should be fully charged in order to be able to measure the 'end' or setpoint voltages of the regulator.
cheers, Peter
FollowupID: 743918
Follow Up By: tg123 - Tuesday, Nov 08, 2011 at 20:53
Thank you all for your well considered replies. Although you left me behind a bit Peter I get the drift re 'smart' vs 'dumb' controllers. Given that the portable panels will only be deployed occasionally when the van is in shade or prolonged cloudy periods it seems that what I intend to do, whilst not the most efficient/smart etc etc will do a reasonable job. My main concern was that I'd be totally screwing up my house batteries and it appears that this will not be the case. Thanks all once again.
TG
FollowupID: 743919
Follow Up By: Robin Miller - Wednesday, Nov 09, 2011 at 07:52
Hi Peter , yep TG
We type to fast sometimes , ( suspect you may not have meant -240mv/degree)
Love it when you sometimes see a voltage like 12.65 - measured with a Dick Smith special.
FollowupID: 743937
Follow Up By: Battery Value Pty Ltd - Wednesday, Nov 09, 2011 at 08:55
yep, how true Robin :)
you can safely ignore the '0' in my -240mV/degree typo lol.
I know, this rollover error of +/- 1 count in the LSD ...but it's only responsible for 0.05% inaccuracy @ 20V FS.
I've found the overall accuracy to be better than 1% on a $12 (from memory Ja.car) unit, which makes these suitable for the type of measurements we're concerned here.
But maybe I just struck it lucky with this unit as the individual accuracy figures could be spread over a broader range.
@Bucky,
very good point, mounting the solar regulator as close to the battery as possible for minimal voltage drop in this wire pair.
cheers, Peter
FollowupID: 743942
Reply By: Member - Bucky - Wednesday, Nov 09, 2011 at 08:10
tg123
Just remember to do what I have done
Get controller as close to battery as humanly possible
It really makes a difference
read
ThreadID: 89551
Date: 15 Oct 2011 07:49
Bucky
AnswerID: 469524
