2002 GU cab chassis series 3 4.2td
Submitted: Saturday, Dec 06, 2003 at 14:16
Rowler
Help Nissanites!
I am going to an auction this wednesday to bid on a 2002 st 4.2td cab chassis which is in excellent condition.
Could anyone supply me with some rough
fuel consumption figures?
Tray not wagon.
Thanks Rowler
Reply By: Member - Peter (WA) - Saturday, Dec 06, 2003 at 15:04
my 1999 4.2 td gets around 7.9 km to the lt unloded , a mate is getting 6.8 km to th lt fully loaded, have a look at the rear spring hanger tops and make sure that they are sitting flat and have not bent up , if so this can be fixed but to have a support rail fitted will cost you about $500This is not my car anymore
York 4x4
39560
Follow Up By: Member - JohnR - Sunday, Dec 07, 2003 at 14:52
Here, here, on your comment on the spring hangers Peter. Just had
mine plated side to side with 12mm after the dealer repair, using the standard bolt holes. I hope the cost may not have been so expensive but did mean the tray had to come off. About three hours total I think.
javascript:WindowPreview('/Members/ViewRig.asp?RigKey=27434.875',700,500) hope this worked
257275
Follow Up By: Rowler - Monday, Dec 08, 2003 at 18:44
If it is bent up is it covered under warranty?
I will carry some heave loads in the back
Thanks Rowler
257349
Follow Up By: Rowler - Monday, Dec 08, 2003 at 18:45
oops!!
Heavy loads
257350
Reply By: Member - Peter (WA) - Saturday, Dec 06, 2003 at 17:34
I have almost finished doing
mine up , I have gone for a fiberglass canopy for rear storage it is light approx 90kg ,and cost less than $3500 including fitting ,linnig etc.I had been looking at metal box type storage for the back but the cheapest was around $7000 plus they came in at over 350kg , This is not my car anymore
York 4x4
39567
Follow Up By: Member - Tim&jan - Saturday, Dec 06, 2003 at 20:34
dont know where you got your canopy from but flexiglass built
mine for 2500 with presserizer,lineing and tradesman windows sounds a bit much for yours? same rig 1999 gu 4.2td ali unicorn traygu bush basha
257256
Follow Up By: Member - Tim&jan - Sunday, Dec 07, 2003 at 17:13
mine is lined with carpet your sayin a grand for roof racks?gu bush basha
257283
Reply By: Member - Tim&jan - Saturday, Dec 06, 2003 at 20:40
Rowler the figers above are pretty spot on getting around 8km to ltr depending on any accessorys i would pay up to 35 to 39k for it?gu bush basha
39581
Follow Up By: Member - Peter (WA) - Sunday, Dec 07, 2003 at 15:30
re the canopy I also had the roof racks added plus the inside was lined with carpet to stop heat and condensationThis is not my car anymore
York 4x4
257276
Follow Up By: Rowler - Monday, Dec 08, 2003 at 18:46
only 2 more sleeps until the auction :-)
257351
Reply By: Mick - Monday, Dec 08, 2003 at 09:59
Hi rowley, i bought my gu DX trayback from
newcastle auctions for $32,000 with no b/bar or accessories. it had 59k on the clock, was from lismore rta. Been a great truck so far, asked a mate at nissan to check out if any warranty probs, all ok no claims, good truck now ive added all the bits.
I havent done a
fuel consumption check yet.
39651
