OT - Tool Identification
Submitted: Saturday, Nov 12, 2011 at 20:40
ThreadID: 90066 Views:3383 Replies:5 FollowUps:20
Image Could Not Be FoundHi All,
I have been going through my father's, grandfather's and father-in-laws tools that I have 'inherited'.
I have one that I wouldn't have a clue what it is for.
Can any one help?
See photo
Reply By: Notso - Saturday, Nov 12, 2011 at 20:45
It's a saw setting tool, designed to put a "Set" on the teeth of a hand saw. So that the saw cut is wider than the saw therfore the saw doesn't stick in the cut.
AnswerID: 469857
Follow Up By: Notso - Saturday, Nov 12, 2011 at 20:46
"Therefore"
FollowupID: 744292
Follow Up By: Member - Tony S (WA) - Saturday, Nov 12, 2011 at 20:50
Hi Notso
You beat me buy two minutes - shouldn't have talked to the Dept of War and Finance.
Tony
The rig
FollowupID: 744293
Reply By: Member - Tony S (WA) - Saturday, Nov 12, 2011 at 20:47
Hi Phantom,
It is a tool for setting the teeth of a hand saw after you have sharpened it.
Tony
The rig
AnswerID: 469858
Follow Up By: Brian Purdue - Saturday, Nov 12, 2011 at 20:55
Not being a "tradesman" I would think that you would "set the saw" before sharpening it. Am I still learning?
FollowupID: 744294
Follow Up By: disco driver - Saturday, Nov 12, 2011 at 21:02
If you are tempted to try it out on one of the "modern Saws" with the hardened teeth,all you will do in break off the teeth.
And at around $10 for a new hard tooth hand saw why would you bother trying to sharpen.
Disco
FollowupID: 744295
Follow Up By: vk1dx - Saturday, Nov 12, 2011 at 21:54
In the days before Bunnings and Mitre 10 and Aldi, long before them, you had to do all the "maintenance" jobs yourself. Saws back then weren't "$10" cheapies. You bought one and looked after it for life. Your life not the saws life. You set and sharpened and oiled it yourself.
That's why you would bother.
I haven't seen one of them for ages. I recognised it but I'll be blowed if I could recall what it was for. They are the type of things you find in the back of the shearing shed lockers.
FollowupID: 744297
Follow Up By: Member - Dunworkin (WA) - Sunday, Nov 13, 2011 at 04:13
Arrrrh those were the days, hard days. Yes I certainly recognised it. I use to use one for setting circular saws way back when, don't think they use them any more, the chain saw has taken over.
Simba, our much missed baby.
FollowupID: 744307
Follow Up By: vk1dx - Sunday, Nov 13, 2011 at 07:57
I may get deleted for being off topic here, but here goes.
Of all the "nom de plumes" that abound these days I like yours; "dunworkin".
Me also but not by choice (medically). But you know what? I damn well miss it!
FollowupID: 744315
Follow Up By: Member - Noel K (NT) - Sunday, Nov 13, 2011 at 12:38
Hey Brian,
The steps to sharpen a saw was the 4 S's....Strip, shape, set and sharpen.
You ran a flat file the length of the blade to bring the tops of the teeth in line.
Shaped the teeth back to the required shape and point.
Set the teeth with that tool to push the teeth over slightly (the tool has different settings for different blades)
Sharpened the cutting edge at an angle.
Old chippies never die.
Regards,
Noel K.
FollowupID: 744344
Follow Up By: Dasherdes - Sunday, Nov 13, 2011 at 20:42
I can remember the first few times that I sharpened a saw. Trying to get rid of the cows and calves afterwards was always a challenge. LOL
Cows and calves was the term we used when you would overshatrpen one side of the saw and ending up with one big tooth and one little tooth.
The carpenter who taught me would make me get the flat file out and file down the teeth and start again. At least he taught me properly.
Haven't hand sharpened a saw for many years now but I could if I had too.
I still have my Spear and Jackson panel saw and tenon saw.
FollowupID: 744397
Reply By: Member - Phantom (WA) - Saturday, Nov 12, 2011 at 20:58
Thanks Fellas,
Maybe I am just too young.lol
Are they worth anything on Ebay?
I have 2 of them.
Steve
AnswerID: 469860
Follow Up By: disco driver - Saturday, Nov 12, 2011 at 21:05
Short Answer...No
You could by one for around $10-15 new.
Disco.
FollowupID: 744296
Reply By: Rockape - Sunday, Nov 13, 2011 at 08:05
Phantom,
Just for your interest.
This is a photo of my grandfathers panel saw, tooth setter and file that I still use and sharpen.
Last week I used it to cut the ends off 3- 4x4 hardwood posts that are over 20 years old. It is a beautiful saw to use and the blade can be bent back and put threw the handle. Great steel.
Have a good one,
RA
AnswerID: 469888
Follow Up By: Daredevildave - Sunday, Nov 13, 2011 at 08:34
I,m still in the trade and use my old Spear & Jackson handsaws regularly.
I prefer them over modern hard tipped saws because they can be resharpened & set unlike the new ones which work great until you hit something hard like a nail or concrete.
PS It would have been hard going cutting a 4x4 hw post with a panel saw.
David
FollowupID: 744316
Follow Up By: Fred G NSW - Sunday, Nov 13, 2011 at 08:44
RA I've a similar couple of saws to that one, one 6 point and a 8 point that I have always looked after myself, and my Dad before me.
Like Phil says, these saws were meant to last your lifetime. Always kept in a canvas saw bag. Every so often you would polish the crap off the blade, and coat it with neatsfoot oil. Who remembers what that is I wonder?
It was a bit of an old chippies badge of honour, so to speak, when you saw one these old saws in someones kit, that were only half or less the depth of blade of a new one, after many years and hundreds of sharpening sessions with the file. You new they had done plenty of hard yakka on the good old Aussie hardwoods.
Great post Phantom.
Fred.
FollowupID: 744317
Follow Up By: Rockape - Sunday, Nov 13, 2011 at 10:57
David,
yes it was hard going. I couldn't use a power saw as the cuts were less than 25mm from a concrete floor and I used the old panel saw to get a neat straight cut.
This post made me go out to the shed and give the old saw a birthday.
Have a good on,
RA.
FollowupID: 744330
Follow Up By: Life Member - esarby (NSW) - Sunday, Nov 13, 2011 at 13:18
My Grandfather was a master carpenter and on weekends he would set and sharpen his saw and I always remember him playing this tune on his large saws. He would tell me that, if it was in tune, it would sound like this.
http://youtu.be/qxUxwiXYUkE
FollowupID: 744353
Follow Up By: gbc - Sunday, Nov 13, 2011 at 21:30
Check the blade and rivets to see if that's a Philadelphia Disston Rockape. Looks like it could be. They are worth some decent money to those who know how to drive them.
We use neatsfoot oil on tack, linseed on timber and boiled off mutton fat on the steel Fred G, and I'd bet I'm closer to half your age.... just brought up right :)
FollowupID: 744399
Follow Up By: gbc - Sunday, Nov 13, 2011 at 21:32
P.S. The rotating dial on the sawset pliers will be marked with a series of numbers which will correspond with the teeth per inch (TPI) of the particular saw you are going to set.
FollowupID: 744400
Follow Up By: eerfree - Sunday, Nov 13, 2011 at 23:55
Rockape and GBC
That handle does indicate a Disston saw but it seems to be missing the medallion so that will affect any value it has.
Ther are lots of different medallions check out the Disston website.
Bob.
FollowupID: 744409
Reply By: The Bantam - Sunday, Nov 13, 2011 at 14:22
Yep its a saw set.
Is it worth anything....possibly it depends on who wants it and the brand and condition.
If ya think you can just go and buy one.....off ya go......good ones are getting a bit hard to come by new.
Why would you use one.....well there are still people out there who use hand tools..among wood workers they are called " dark siders".
One very good reason you would use one IF you are skilled and fussy, is that it allows youy to sharpen the saw exactly how you want it for a particular type of work...differing amounts of set, tooth shapes and cutting angles.
For some work you can not compete with a properly maintained hand tool in skilled hands.
AnswerID: 469918
Follow Up By: Brian Purdue - Sunday, Nov 13, 2011 at 22:23
Bantam, those were the days. My "Dad" made all his own tools including a micrometer. The days of a "Fitter, turner & toolmaker" He is long since gone as has his trade. I was only a "pen-pusher" and it had little or no regard for me or my qualifications. I will be 79 before the end of the year and was considered to be pretty good at my job but never made anything of a tool except for a mess. Now there are very few trade apprentices and the world is worse off because most tradesmen replace not fix.
FollowupID: 744405
Follow Up By: The Bantam - Monday, Nov 14, 2011 at 10:31
Ya got that right...there are "tradesmen" out there who do not know how to sharpen a chisel.
FollowupID: 744427
Follow Up By: Member - Christopher P (NSW) - Wednesday, Nov 16, 2011 at 21:16
well i am 36 and i have learnt how to sharpen chainsaws and hand saws, but it is a skill i rarely use these days. i still prefer pulling out a hand saw rather than my shiny new gmc circular saw. I even use a mitre box on occasion.
Very few proper chippys these days... i do know one, but he was a timber boat builder (shipwright) before the fibre glass and mass production. very very precise...
i can also do splicing. not many people around my age and younger even know how to splice.
FollowupID: 744663
